Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Turn the laptop over so its underside is facing upwards and visible.
Standing so that the barcode and warning labels are upright and legible, push the left tab up and away from yourself.
Standing so that the barcode and warning labels are upright and legible, push the right tab up and away from yourself.
Locate the small gap where the battery and the laptop shell meet. Lift from the gap and rotate the battery up and away from yourself.
Remove 2 bottom screws in the top right on the HDD cover, with a size P000 screwdriver.
Remove the screws on the HDD with a Phillips #000 screwdriver.
Pull plastic tab away from the laptop.
Lift HDD away from laptop.
Follow wire down its wire channel and remove it from the channel.
Pull up on the connector to disconnect the speakers to the motherboard.
Bir başkası bu kılavuzu tamamladı.
