Giriş
If you want to upgrade the GPU, the graphics card or even the storage capacity, you might also need to upgrade the motherboard.
Follow this guide to safety remove and replace the motherboard.
Neye ihtiyacın var
Turn the laptop facedown.
Locate the battery compartment at the top of the laptop base. You will see two tabs on it.
Push the two tabs up to release the battery. Set it aside.
Remove the cables from the fan and unscrew the heatsink.
Carefully disconnect the tabs on the edges of the motherboard.
Unscrew the screws holding the motherboard in place. Set them aside.
On the underside of the motherboard, disconnect the keyboard from the motherboard.
Once ALL cables are disconnected, carefully remove the motherboard.
