Ana içeriğe geç
Sony Vaio SVF15A16CXB Battery Replacement
Neye ihtiyacın var
  1. Sony Vaio SVF15A16CXB Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
    • 6 mm screws marked in red, 4 mm marked in orange
  2. Sony Vaio SVF15A16CXB Battery Replacement: adım 2, 2 resimden 1. Sony Vaio SVF15A16CXB Battery Replacement: adım 2, 2 resimden 2.
    • Using a plastic opening tool, pull the optical drive out of the computer by the seam.
    • In reassembly, slide the optical drive back in after reapplying cover.
  3. Sony Vaio SVF15A16CXB Battery Replacement: adım 3, 1 resimden 1.
    • Run the opening tool along the bottom cover seam.
  4. Sony Vaio SVF15A16CXB Battery Replacement: adım 4, 1 resimden 1.
    • Lift the clip marked in red in order to release the back cover.
    • Lift the back cover.
  5. Sony Vaio SVF15A16CXB Battery Replacement, Battery: adım 5, 1 resimden 1.
    • Unscrew the four 6mm screws with the Phillips #0 screwdriver.
  6. Sony Vaio SVF15A16CXB Battery Replacement: adım 6, 1 resimden 1.
    • Lift the battery and remove it from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 2,717
