Neye ihtiyacın var
Unscrew the eleven 6 mm screws from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
Unscrew the one 4 mm screw from the back panel on the bottom of laptop with the Phillips #0 screwdriver.
Unscrew the three 4mm screws with the Phillips #0 screwdriver located on the outer edge of the hard drive.
Bir başkası bu kılavuzu tamamladı.
