Ana içeriğe geç
Sony Vaio SVS151190X Disk Reader Replacement
Neye ihtiyacın var
  1. Sony Vaio SVS151190X Disk Reader Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Using a #1 Phillips screwdriver, remove the two 5mm screws as directed.
    • Slide off the back cover.
    • Ensure different sized screws are kept separate during disassembly.
  2. Sony Vaio SVS151190X Disk Reader Replacement: adım 2, 1 resimden 1.
    • Remove the four 3mm screws using the Phillips #1 screwdriver.
  3. Sony Vaio SVS151190X Disk Reader Replacement: adım 3, 1 resimden 1.
    • Lift out the hard drive and unplug the orange ribbon wire.
  4. Sony Vaio SVS151190X Disk Reader Replacement, Disk Reader: adım 4, 1 resimden 1.
    • To loosen the keyboard, remove the twenty 5mm screws using the Phillips #1 screwdriver.
  5. Sony Vaio SVS151190X Disk Reader Replacement: adım 5, 1 resimden 1.
    • Flip the device over and open it up.
    • Using a plastic opening tool and opening picks, pry off the keyboard from the bottom cover. Start from one of the corners of the device and work your way around.
    • The bottom cover is somewhat fragile, do not be too forceful when prying off the keyboard.
  6. Sony Vaio SVS151190X Disk Reader Replacement: adım 6, 2 resimden 1. Sony Vaio SVS151190X Disk Reader Replacement: adım 6, 2 resimden 2.
    • The ribbon wire that attaches the keyboard and bottom cover is fragile, take care during removal.
    • Remove the keyboard from the bottom cover and place it down as demonstrated.
    • Carefully pull the plastic tab and remove the ribbon wire.
  7. Sony Vaio SVS151190X Disk Reader Replacement: adım 7, 2 resimden 1. Sony Vaio SVS151190X Disk Reader Replacement: adım 7, 2 resimden 2.
    • Slightly pull up the black tape covering the disk drive's ribbon wire.
    • Pull up the blue plastic strip attached to the ribbon wire and remove the ribbon wire from the port.
    • Detach the ribbon wire from the fan so the disk reader can be removed.
  8. Sony Vaio SVS151190X Disk Reader Replacement: adım 8, 1 resimden 1.
    • Remove the two 3mm screws using the Phillips #1 screwdriver.
  9. Sony Vaio SVS151190X Disk Reader Replacement: adım 9, 2 resimden 1. Sony Vaio SVS151190X Disk Reader Replacement: adım 9, 2 resimden 2.
    • Take out the black plastic covering.
    • Remove the disk reader.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 573
