Giriş
We will be replacing the WiFi card in a Sony Vaio SVS151190X laptop. If your device is unable to connect to Wireless Internet, you may need to replace your card. A replacement may be in order if your current WiFi card is old, damaged, or faulty. Before buying/installing a new card ensure that your router is running properly and all your security credentials are correct .
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Using a #1 Phillips screwdriver, remove the two 5mm screws.
Slide off the back cover.
Neredeyse bitti!
Sonuç
