Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
The display replacement for the Sony Vaio T13 series of laptops the most intricate and time-consuming replacement process. Allocate about 1-2 hours for this replacement, making sure to take your time and keep your screws organized.
The replacement display should be 13.3" in size, and should specify a native resolution of 1366x768.
Neye ihtiyacın var
Carefully grab the edges of the laptop and flip it over to reveal the back panel.
The battery is located on the lower half of the back panel, and contains three 10mm flat-head screws.
Unscrew the three 10mm flat-head screws using a flat-head screw driver.
Lift the battery from the lip closest to the middle screw to remove the battery entirely.
The middle Phillips head screw is 10mm in length and will only fit in this thread. Unscrew the 10mm Phillips head screw and keep it separate from the other two screws in this step.
Unscrew the two remaining 5mm Phillips head screws on the left and right side of the hard drive bay cover.
Lift the panel to remove it.
Unscrew the two 5mm Phillips head screws that secure the two display hinges to the back panel of the laptop.
Carefully lift the metal hinges that secure the top panel to the bottom panel of the laptop.
Slowly slide the bottom panel of the laptop out from under the metal hinges. Your display panel will now be separated from the rest of your device.
4 farklı kişi bu kılavuzu tamamladı.
