Ana içeriğe geç
Sony Vaio SVT151A11L SSD Replacement
Neye ihtiyacın var
  1. Sony Vaio SVT151A11L SSD Replacement, Battery: adım 1, 2 resimden 1. Sony Vaio SVT151A11L SSD Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the laptop over so that the battery on the underside of the device is revealed.
    • Unscrew the two 11mm slotted silver screws that can be found at the top of the battery.
  2. Sony Vaio SVT151A11L SSD Replacement: adım 2, 3 resimden 1. Sony Vaio SVT151A11L SSD Replacement: adım 2, 3 resimden 2. Sony Vaio SVT151A11L SSD Replacement: adım 2, 3 resimden 3.
    • Wedge the plastic opening tool between the back panel and the battery on the top left side of the device.
    • Push down on the plastic opening tool until the battery lifts from the back of the laptop.
    • Grab the battery and remove it from the device.
  3. Sony Vaio SVT151A11L SSD Replacement, Back Panel: adım 3, 3 resimden 1. Sony Vaio SVT151A11L SSD Replacement, Back Panel: adım 3, 3 resimden 2. Sony Vaio SVT151A11L SSD Replacement, Back Panel: adım 3, 3 resimden 3.
    • Unscrew the three 4mm screws using a JIS #0 screwdriver.
    • Unscrew the eight 7 mm screws using a JIS #0 screwdriver.
    • Grab and lift the edge of the panel to pull it free from the rest of the computer.
  4. Sony Vaio SVT151A11L SSD Replacement: adım 4, 3 resimden 1. Sony Vaio SVT151A11L SSD Replacement: adım 4, 3 resimden 2. Sony Vaio SVT151A11L SSD Replacement: adım 4, 3 resimden 3.
    • Grab the disk drive located at the edge of the computer and pull it it out.
    • Unscrew the three 7 mm screws with a JIS #0 screwdriver.
  5. Sony Vaio SVT151A11L SSD Replacement, SSD: adım 5, 3 resimden 1. Sony Vaio SVT151A11L SSD Replacement, SSD: adım 5, 3 resimden 2. Sony Vaio SVT151A11L SSD Replacement, SSD: adım 5, 3 resimden 3.
    • Unscrew single 4mm screw using a JIS #0 screwdriver.
    • Lift up one end of the SSD.
    • Pull the SSD from its port.
  6. Sony Vaio SVT151A11L SSD Replacement: adım 6, 1 resimden 1.
    • Leave the port empty so that a new SSD can be placed inside.
Sonuç
Nathan McGarvey
481 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G6, Julie Fall 2017 UMass Dartmouth, Team S4-G6, Julie Fall 2017 üyesi
UMASSD-JULIE-F17S4G6
2 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 25
Her zaman: 3,687
