Ana içeriğe geç
Sony Vaio Tap 11 Battery Replacement
Neye ihtiyacın var
  1. Sony Vaio Tap 11 Battery Replacement, Screen Assembly: adım 1, 1 resimden 1.
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Battery Replacement: adım 2, 1 resimden 1.
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Battery Replacement: adım 3, 2 resimden 1. Sony Vaio Tap 11 Battery Replacement: adım 3, 2 resimden 2.
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Disconnect the battery from the motherboard by pulling out the cable below the fan.
  5. Sony Vaio Tap 11 Battery Replacement: adım 5, 1 resimden 1.
    • Remove the seven 3 mm Phillips #000 screws that hold the battery in place.
    • Carefully remove the battery from the back assembly.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Alexander Bridges
1.217 İtibar
7 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Harley Fall 2015 IUPUI, Team 1-2, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S1G2
4 Üyeler
20 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 6,052
