Ana içeriğe geç
Sony Vaio Tap 11 Screen Camera Module Replacement Replacement
Neye ihtiyacın var
    1. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement, Screen Assembly: adım 1, 1 resimden 1.
      • Begin by opening the HDMI/USB port cover on the left edge.
      • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: adım 2, 1 resimden 1.
      • Locate and open the Micro SD slot on the top side of the device.
      • Remove the two screws located beneath the cover.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: adım 3, 2 resimden 1. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: adım 3, 2 resimden 2.
      • Attach the suction cup to the top right area of the screen.
      • Pull to separate the screen from the rest of the device.
      • Be aware of the front camera cable that is still connected to the rest of the device.
      • Detach the display ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement, Screen Camera Module Replacement: adım 4, 1 resimden 1.
      • Flip device upward carefully like you are turning the page of a book.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: adım 5, 1 resimden 1.
      • Disconnect the camera cable from the device backing.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: adım 6, 1 resimden 1.
      • Remove the single 3 mm Phillips #000 screw on the left side of the module.
      • Remove the module from the front panel assembly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nick Catanzarite
188 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Harley Fall 2015 IUPUI, Team 1-2, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S1G2
4 Üyeler
20 adet Kılavuz yazıldı
1Rehber Yorum
Is it possible to replace the camera module with a different one? I think that it is a usb camera. I would like to replace it a newer sony model.
Matthew Harper - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 59
Her zaman: 1,366
