Ana içeriğe geç
Sony Vaio Tap 11 Wifi Module Replacement
Neye ihtiyacın var
  1. Sony Vaio Tap 11 Wifi Module Replacement, Screen Assembly: adım 1, 1 resimden 1.
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Wifi Module Replacement: adım 2, 1 resimden 1.
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Wifi Module Replacement: adım 3, 2 resimden 1. Sony Vaio Tap 11 Wifi Module Replacement: adım 3, 2 resimden 2.
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Wifi Module Replacement, Solid State Disk: adım 4, 1 resimden 1.
    • Unplug the battery connector located beside the fan.
    • Locate the SSD on the right side of the device, above the battery and beneath the WiFi chip.
  5. Sony Vaio Tap 11 Wifi Module Replacement: adım 5, 1 resimden 1.
    • Remove the two 3 mm Phillips #000 screws from the right edge of the SSD.
  6. Sony Vaio Tap 11 Wifi Module Replacement: adım 6, 2 resimden 1. Sony Vaio Tap 11 Wifi Module Replacement: adım 6, 2 resimden 2.
    • Pull the SSD towards the right and slightly up, removing it from the back assembly.
  7. Sony Vaio Tap 11 Wifi Module Replacement, Wifi Module: adım 7, 3 resimden 1. Sony Vaio Tap 11 Wifi Module Replacement, Wifi Module: adım 7, 3 resimden 2. Sony Vaio Tap 11 Wifi Module Replacement, Wifi Module: adım 7, 3 resimden 3.
    • Begin by removing the orange ribbon cable connecting the motherboard to the daughterboard, located above the SSD.
    • Gently tug either side until it releases, then pull out the other end.
  8. Sony Vaio Tap 11 Wifi Module Replacement: adım 8, 1 resimden 1.
    • Remove the grey foam separator that was underneath the orange ribbon cable.
  9. Sony Vaio Tap 11 Wifi Module Replacement: adım 9, 1 resimden 1.
    • Remove the silver 3 mm Phillips screw that holds the WiFi module in place.
  10. Sony Vaio Tap 11 Wifi Module Replacement: adım 10, 1 resimden 1.
    • Remove the black and grey antenna cables from the right side of the device.
  11. Sony Vaio Tap 11 Wifi Module Replacement: adım 11, 1 resimden 1.
    • Remove module by gently pulling towards the right.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alexander Bridges
1.217 İtibar
7 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Harley Fall 2015 IUPUI, Team 1-2, Harley Fall 2015 üyesi
IUPUI-HARLEY-F15S1G2
4 Üyeler
20 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 2,178
