Giriş
Use this guide to replace the fan on a Sony Vaio Tap 21 all-in-one desktop. The fan has a copper attachment on the motherboard . The actual fan itself is between the two speakers. The fan might need replacing if the device is overheating more than usual.
Neye ihtiyacın var
Insert the plastic opening tool at an angle into the grill and lift the tab by applying force down and to the left as you are lifting it out of place.
Use your plastic opening tool to remove the right plastic tab blocking the screw mounts behind the device.
The plastic tab is located on a plastic stretch of grill running along the upper half of the back of the device.
Remove four 9mm screws from the fan attachment located on the motherboard with a Phillips #1 screwdriver.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Very nice guide. Thank you. Have you replaced the CPU yet in this model?
