Ana içeriğe geç
Sony Vaio VGN-FS640 Fan Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Sony Vaio VGN-FS640 Fan Replacement, Backplate: adım 1, 1 resimden 1.
    • Turn off the laptop and disconnect any charging cables.
    • Flip the laptop over so that the Service Tag is shown at the top left corner.
  2. Sony Vaio VGN-FS640 Fan Replacement: adım 2, 1 resimden 1.
    • Remove the highlighted screws from the back of the laptop with a Phillips #0 Screwdriver.
  3. Sony Vaio VGN-FS640 Fan Replacement: adım 3, 1 resimden 1.
    • Remove the highlighted screws from the panels in the bottom right-hand corner of the laptop using the Phillips #0 Screwdriver.
  4. Sony Vaio VGN-FS640 Fan Replacement: adım 4, 1 resimden 1.
    • Remove the two panels in the bottom right-hand corner by sliding in the direction of the arrows imprinted on the panels.
  5. Sony Vaio VGN-FS640 Fan Replacement: adım 5, 1 resimden 1.
    • Remove the highlighted screws underneath the removed panels using the Phillips #0 Screwdriver.
  6. Sony Vaio VGN-FS640 Fan Replacement: adım 6, 1 resimden 1.
    • Carefully remove the hard drive from the panel in the bottom right-hand corner of the laptop.
  7. Sony Vaio VGN-FS640 Fan Replacement: adım 7, 1 resimden 1.
    • Locate the battery, located on the top side of the laptop to the right of the Service Tag .
    • Remove the battery by pressing inwards on the tabs on either side of the battery.
  8. Sony Vaio VGN-FS640 Fan Replacement: adım 8, 1 resimden 1.
    • Remove cover in the top left side of the laptop next to the battery by pulling it outwards.
  9. Sony Vaio VGN-FS640 Fan Replacement: adım 9, 1 resimden 1.
    • Remove the backplate of the laptop by pulling it away from the laptop.
  10. Sony Vaio VGN-FS640 Fan Replacement, Fan: adım 10, 3 resimden 1. Sony Vaio VGN-FS640 Fan Replacement, Fan: adım 10, 3 resimden 2. Sony Vaio VGN-FS640 Fan Replacement, Fan: adım 10, 3 resimden 3.
    • Gently remove the connector for the wire running over the fan by lifting the tab on top up with your fingernail and sliding it out.
  11. Sony Vaio VGN-FS640 Fan Replacement: adım 11, 2 resimden 1. Sony Vaio VGN-FS640 Fan Replacement: adım 11, 2 resimden 2.
    • Remove the four screws securing the fan.
  12. Sony Vaio VGN-FS640 Fan Replacement: adım 12, 2 resimden 1. Sony Vaio VGN-FS640 Fan Replacement: adım 12, 2 resimden 2.
    • Gently lift out the fan.
    • Do not forcefully pull the fan away. This may damage the circuit board.
  13. Sony Vaio VGN-FS640 Fan Replacement: adım 13, 2 resimden 1. Sony Vaio VGN-FS640 Fan Replacement: adım 13, 2 resimden 2.
    • Gently disconnect the remaining wire connecting the fan to the circuit board.
    • Remove the fan from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Geoffrey
252 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-6, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 2-6, Vijaybhaskar Spring 2014 üyesi
UMASSD-VIJAYBHASKAR-S14S2G6
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 558
