Ana içeriğe geç
Sony Vaio VGN-FS640 Hard Drive Replacement
Neye ihtiyacın var
  1. Sony Vaio VGN-FS640 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Lay the closed laptop on its screen so the bottom is facing towards you.
  2. Sony Vaio VGN-FS640 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Push both latches towards the center of the battery.
  3. Sony Vaio VGN-FS640 Hard Drive Replacement: adım 3, 2 resimden 1. Sony Vaio VGN-FS640 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Revome the battery by pushing it away from the laptop.
    • Set the battery away from the laptop.
  4. Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 1. Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 2. Sony Vaio VGN-FS640 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 3.
    • Locate and remove the screw (Length: 7.7mm) for the hard drive cover.
    • Slide the cover until it is free from the laptop case.
    • Lift the cover to remove.
  5. Sony Vaio VGN-FS640 Hard Drive Replacement: adım 5, 3 resimden 1. Sony Vaio VGN-FS640 Hard Drive Replacement: adım 5, 3 resimden 2. Sony Vaio VGN-FS640 Hard Drive Replacement: adım 5, 3 resimden 3.
    • Locate and remove the four screws (Length: 7.7mm) holding the Hard Drive tray in place.
    • Using the tab on the tray, slide the Hard Drive away from the main body of the laptop.
    • The Hard Drive should now be disconnected.
    • Lift the drive out with the tab on the tray.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matt McCarty
220 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-32, Regan Spring 2010 Cal Poly, Team 24-32, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G32
4 Üyeler
16 adet Kılavuz yazıldı
Bir Yorum
cant sign to recover my external hard drive
manivanan88 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 14
Her zaman: 10,578
