Ana içeriğe geç
Sony Vaio VGN-FS640 RAM Replacement
Neye ihtiyacın var
  1. Sony Vaio VGN-FS640 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Lay the closed laptop on its screen so the bottom is facing towards you.
    FixBot'a Sor
    Yorum Ekle
  2. Sony Vaio VGN-FS640 RAM Replacement: adım 2, 1 resimden 1.
    • Push both latches towards the center of the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Sony Vaio VGN-FS640 RAM Replacement: adım 3, 2 resimden 1. Sony Vaio VGN-FS640 RAM Replacement: adım 3, 2 resimden 2.
    • Revome the battery by pushing it away from the laptop.
    • Set the battery away from the laptop.
    FixBot'a Sor
    Yorum Ekle
  4. Sony Vaio VGN-FS640 RAM Replacement, RAM Cover: adım 4, 2 resimden 1. Sony Vaio VGN-FS640 RAM Replacement, RAM Cover: adım 4, 2 resimden 2.
    • With the bottom of the laptop facing up, locate the RAM cover.
    • The RAM is covered by the panel with four columns of vents.
    • Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. Sony Vaio VGN-FS640 RAM Replacement: adım 5, 3 resimden 1. Sony Vaio VGN-FS640 RAM Replacement: adım 5, 3 resimden 2. Sony Vaio VGN-FS640 RAM Replacement: adım 5, 3 resimden 3.
    • Use your fingers to slide the cover away from the laptop. (It will only slide a few millimeters)
    • Once the panel is out of its locked position, it can be lifted out without any resistance.
    FixBot'a Sor
    Yorum Ekle
  6. Sony Vaio VGN-FS640 RAM Replacement, RAM: adım 6, 3 resimden 1. Sony Vaio VGN-FS640 RAM Replacement, RAM: adım 6, 3 resimden 2. Sony Vaio VGN-FS640 RAM Replacement, RAM: adım 6, 3 resimden 3.
    • To remove the RAM, use sharp end of a spudger to push the two silver tabs (see picture) away from the green RAM chip.
    • When both silver tabs are moved to the side, one edge of the RAM chip will pop up from its original position.
    • Use your fingers to grab the raised edge of the RAM and pull the chip away from its connection to the laptop.
    FixBot'a Sor
    Yorum Ekle
  7. Sony Vaio VGN-FS640 RAM Replacement: adım 7, 1 resimden 1.
    • To install the new RAM, grip the new chip exactly the same way as you gripped the old chip when you removed it.
    • Insert the gold leads of the RAM into the connection at the same angle the original chip was raised at after the tabs were released.
    • There is a raised tab on the connection that mates with a slit in the RAM to ensure you do not put the chip in upside down.
    FixBot'a Sor
    Yorum Ekle
  8. Sony Vaio VGN-FS640 RAM Replacement: adım 8, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Michael Maravick
75 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 24-32, Regan Spring 2010 Cal Poly, Team 24-32, Regan Spring 2010 üyesi
CPSU-REGAN-S10S24G32
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 31
Her zaman: 10,945
