Ana içeriğe geç
Sony Vaio VGN-S260 Ethernet Ports Replacement
Neye ihtiyacın var
  1. Sony Vaio VGN-S260 Ethernet Ports Replacement, Battery: adım 1, 3 resimden 1. Sony Vaio VGN-S260 Ethernet Ports Replacement, Battery: adım 1, 3 resimden 2. Sony Vaio VGN-S260 Ethernet Ports Replacement, Battery: adım 1, 3 resimden 3.
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 2, 2 resimden 1. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 2, 2 resimden 2.
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Sony Vaio VGN-S260 Ethernet Ports Replacement, Keyboard: adım 3, 2 resimden 1. Sony Vaio VGN-S260 Ethernet Ports Replacement, Keyboard: adım 3, 2 resimden 2.
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 4, 1 resimden 1.
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 5, 2 resimden 1. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 5, 2 resimden 2.
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  6. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 6, 2 resimden 1. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 6, 2 resimden 2.
    • Lift up lever underneath the ribbon to detach the keyboard.
  7. Sony Vaio VGN-S260 Ethernet Ports Replacement, Upper Casing: adım 7, 1 resimden 1.
    • Remove memory/wireless compartment cover.
  8. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 8, 3 resimden 1. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 8, 3 resimden 2. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 8, 3 resimden 3.
    • Flip so the Vaio Logo is face down.
    • Locate and remove a total of 8 screws on the bottom.
  9. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 9, 1 resimden 1.
    • Find and remove 5 screws (they all have arrows next to them) from cover.
  10. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 10, 3 resimden 1. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 10, 3 resimden 2. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 10, 3 resimden 3.
    • Flip the laptop over so the Vaio logo is face up.
    • Use the spudger to pop up the upper casing.
    • Do not lift too much as the upper casing is attached to wires underneath.
    • Remove the wires that are attaching the upper casing to the motherboard.
  11. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 11, 1 resimden 1.
    • Remove the upper casing.
  12. Sony Vaio VGN-S260 Ethernet Ports Replacement, Optical Drive: adım 12, 1 resimden 1.
    • Remove the screw holding the optical drive casing to the logic board.
  13. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 13, 1 resimden 1.
    • Locate ribbon connecting optical drive case to logic board.
    • Pop off the ribbon.
    • Remove the metal PC-Card cage.
  14. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 14, 1 resimden 1.
    • Remove the four screws holding the optical drive to the logic board.
  15. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 15, 2 resimden 1. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 15, 2 resimden 2.
    • Locate brown locking tab above optical drive.
    • Lift up on brown locking tab until ribbon is loose.
    • Gently slide out and remove the optical drive from the computer.
  16. Sony Vaio VGN-S260 Ethernet Ports Replacement, Ethernet Ports: adım 16, 2 resimden 1. Sony Vaio VGN-S260 Ethernet Ports Replacement, Ethernet Ports: adım 16, 2 resimden 2.
    • Remove the blue ribbon from the Ethernet Circuit Board.
  17. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 17, 1 resimden 1.
    • Remove the screws near the Ethernet Port circuit board.
  18. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 18, 1 resimden 1.
    • Remove the screws for the second ethernet circuit board.
  19. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 19, 2 resimden 1. Sony Vaio VGN-S260 Ethernet Ports Replacement: adım 19, 2 resimden 2.
    • Remove the ethernet ports.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jeffrey Bryan
570 İtibar
11 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-4, Maness Spring 2010 Cal Poly, Team 16-4, Maness Spring 2010 üyesi
CPSU-MANESS-S10S16G4
4 Üyeler
30 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 3,540
