Ana içeriğe geç
Sony Vaio VGN-S260 Fan Replacement
Neye ihtiyacın var
  1. Sony Vaio VGN-S260 Fan Replacement, Battery: adım 1, 3 resimden 1. Sony Vaio VGN-S260 Fan Replacement, Battery: adım 1, 3 resimden 2. Sony Vaio VGN-S260 Fan Replacement, Battery: adım 1, 3 resimden 3.
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. Sony Vaio VGN-S260 Fan Replacement: adım 2, 2 resimden 1. Sony Vaio VGN-S260 Fan Replacement: adım 2, 2 resimden 2.
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Sony Vaio VGN-S260 Fan Replacement, Keyboard: adım 3, 2 resimden 1. Sony Vaio VGN-S260 Fan Replacement, Keyboard: adım 3, 2 resimden 2.
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Sony Vaio VGN-S260 Fan Replacement: adım 4, 1 resimden 1.
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. Sony Vaio VGN-S260 Fan Replacement: adım 5, 2 resimden 1. Sony Vaio VGN-S260 Fan Replacement: adım 5, 2 resimden 2.
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  6. Sony Vaio VGN-S260 Fan Replacement: adım 6, 2 resimden 1. Sony Vaio VGN-S260 Fan Replacement: adım 6, 2 resimden 2.
    • Lift up lever underneath the ribbon to detach the keyboard.
  7. Sony Vaio VGN-S260 Fan Replacement, Upper Casing: adım 7, 1 resimden 1.
    • Remove memory/wireless compartment cover.
  8. Sony Vaio VGN-S260 Fan Replacement: adım 8, 3 resimden 1. Sony Vaio VGN-S260 Fan Replacement: adım 8, 3 resimden 2. Sony Vaio VGN-S260 Fan Replacement: adım 8, 3 resimden 3.
    • Flip so the Vaio Logo is face down.
    • Locate and remove a total of 8 screws on the bottom.
  9. Sony Vaio VGN-S260 Fan Replacement: adım 9, 1 resimden 1.
    • Find and remove 5 screws (they all have arrows next to them) from cover.
  10. Sony Vaio VGN-S260 Fan Replacement: adım 10, 3 resimden 1. Sony Vaio VGN-S260 Fan Replacement: adım 10, 3 resimden 2. Sony Vaio VGN-S260 Fan Replacement: adım 10, 3 resimden 3.
    • Flip the laptop over so the Vaio logo is face up.
    • Use the spudger to pop up the upper casing.
    • Do not lift too much as the upper casing is attached to wires underneath.
    • Remove the wires that are attaching the upper casing to the motherboard.
  11. Sony Vaio VGN-S260 Fan Replacement: adım 11, 1 resimden 1.
    • Remove the upper casing.
  12. Sony Vaio VGN-S260 Fan Replacement, Optical Drive: adım 12, 1 resimden 1.
    • Remove the screw holding the optical drive casing to the logic board.
  13. Sony Vaio VGN-S260 Fan Replacement: adım 13, 1 resimden 1.
    • Locate ribbon connecting optical drive case to logic board.
    • Pop off the ribbon.
    • Remove the metal PC-Card cage.
  14. Sony Vaio VGN-S260 Fan Replacement: adım 14, 1 resimden 1.
    • Remove the four screws holding the optical drive to the logic board.
  15. Sony Vaio VGN-S260 Fan Replacement: adım 15, 2 resimden 1. Sony Vaio VGN-S260 Fan Replacement: adım 15, 2 resimden 2.
    • Locate brown locking tab above optical drive.
    • Lift up on brown locking tab until ribbon is loose.
    • Gently slide out and remove the optical drive from the computer.
  16. Sony Vaio VGN-S260 Fan Replacement, Ethernet Ports: adım 16, 2 resimden 1. Sony Vaio VGN-S260 Fan Replacement, Ethernet Ports: adım 16, 2 resimden 2.
    • Remove the blue ribbon from the Ethernet Circuit Board.
  17. Sony Vaio VGN-S260 Fan Replacement: adım 17, 1 resimden 1.
    • Remove the screws near the Ethernet Port circuit board.
  18. Sony Vaio VGN-S260 Fan Replacement: adım 18, 1 resimden 1.
    • Remove the screws for the second ethernet circuit board.
  19. Sony Vaio VGN-S260 Fan Replacement: adım 19, 2 resimden 1. Sony Vaio VGN-S260 Fan Replacement: adım 19, 2 resimden 2.
    • Remove the ethernet ports.
  20. Sony Vaio VGN-S260 Fan Replacement, Hard Drive: adım 20, 2 resimden 1. Sony Vaio VGN-S260 Fan Replacement, Hard Drive: adım 20, 2 resimden 2.
    • Remove the screws holding the hard drive casing in place.
  21. Sony Vaio VGN-S260 Fan Replacement: adım 21, 1 resimden 1.
    • Find orange ribbon that is connected to the hard drive.
    • Find the holder of the ribbon and pop the ribbon off from it.
  22. Sony Vaio VGN-S260 Fan Replacement: adım 22, 1 resimden 1.
    • Remove the casing and the orange ribbon.
  23. Sony Vaio VGN-S260 Fan Replacement, Power Adapter: adım 23, 2 resimden 1. Sony Vaio VGN-S260 Fan Replacement, Power Adapter: adım 23, 2 resimden 2.
    • Locate the yellow power adapter.
    • Follow its wire to white logic board connector.
    • Pull out the wire from white logic board connector.
  24. Sony Vaio VGN-S260 Fan Replacement: adım 24, 3 resimden 1. Sony Vaio VGN-S260 Fan Replacement: adım 24, 3 resimden 2. Sony Vaio VGN-S260 Fan Replacement: adım 24, 3 resimden 3.
    • Locate the screws on the fan filter casing.
    • Remove these screws.
  25. Sony Vaio VGN-S260 Fan Replacement: adım 25, 2 resimden 1. Sony Vaio VGN-S260 Fan Replacement: adım 25, 2 resimden 2.
    • Remove the screw next to the yellow power adapter.
    • Lift out power adapter and fan filter.
  26. Sony Vaio VGN-S260 Fan Replacement, Motherboard: adım 26, 2 resimden 1. Sony Vaio VGN-S260 Fan Replacement, Motherboard: adım 26, 2 resimden 2.
    • Remove screws on the motherboard.
  27. Sony Vaio VGN-S260 Fan Replacement: adım 27, 2 resimden 1. Sony Vaio VGN-S260 Fan Replacement: adım 27, 2 resimden 2.
    • Remove the nut using a 5mm nut driver.
    • Using a magnetic screwdriver handle will also work as well.
  28. Sony Vaio VGN-S260 Fan Replacement: adım 28, 2 resimden 1. Sony Vaio VGN-S260 Fan Replacement: adım 28, 2 resimden 2.
    • Remove the LCD display ribbon with a nylon spudger.
    • This is difficult to remove.
  29. Sony Vaio VGN-S260 Fan Replacement: adım 29, 3 resimden 1. Sony Vaio VGN-S260 Fan Replacement: adım 29, 3 resimden 2. Sony Vaio VGN-S260 Fan Replacement: adım 29, 3 resimden 3.
    • Gently lift the motherboard from the laptop.
    • The motherboard will be attached to the network wireless chip, which is also attached to the base of the laptop.
    • Remove the chip by popping the tabs on the side.
    • Slide out the network card.
    • You are now free to take the motherboard away from the base.
  30. Sony Vaio VGN-S260 Fan Replacement, Fan: adım 30, 1 resimden 1.
    • Disconnect the fan wire from the logic board
  31. Sony Vaio VGN-S260 Fan Replacement: adım 31, 2 resimden 1. Sony Vaio VGN-S260 Fan Replacement: adım 31, 2 resimden 2.
    • Turn the logic board over and Locate the screws connecting the fan to the logic board
    • Gently remove the fan from the logic board
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jeffrey Bryan
570 İtibar
11 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-4, Maness Spring 2010 Cal Poly, Team 16-4, Maness Spring 2010 üyesi
CPSU-MANESS-S10S16G4
4 Üyeler
30 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 8,360
