Ana içeriğe geç
Sony Vaio VGN-S260 Motherboard Replacement
Neye ihtiyacın var
  1. Sony Vaio VGN-S260 Motherboard Replacement, Battery: adım 1, 3 resimden 1. Sony Vaio VGN-S260 Motherboard Replacement, Battery: adım 1, 3 resimden 2. Sony Vaio VGN-S260 Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. Sony Vaio VGN-S260 Motherboard Replacement: adım 2, 2 resimden 1. Sony Vaio VGN-S260 Motherboard Replacement: adım 2, 2 resimden 2.
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Sony Vaio VGN-S260 Motherboard Replacement, Keyboard: adım 3, 2 resimden 1. Sony Vaio VGN-S260 Motherboard Replacement, Keyboard: adım 3, 2 resimden 2.
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Sony Vaio VGN-S260 Motherboard Replacement: adım 4, 1 resimden 1.
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. Sony Vaio VGN-S260 Motherboard Replacement: adım 5, 2 resimden 1. Sony Vaio VGN-S260 Motherboard Replacement: adım 5, 2 resimden 2.
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  6. Sony Vaio VGN-S260 Motherboard Replacement: adım 6, 2 resimden 1. Sony Vaio VGN-S260 Motherboard Replacement: adım 6, 2 resimden 2.
    • Lift up lever underneath the ribbon to detach the keyboard.
  7. Sony Vaio VGN-S260 Motherboard Replacement, Upper Casing: adım 7, 1 resimden 1.
    • Remove memory/wireless compartment cover.
  8. Sony Vaio VGN-S260 Motherboard Replacement: adım 8, 3 resimden 1. Sony Vaio VGN-S260 Motherboard Replacement: adım 8, 3 resimden 2. Sony Vaio VGN-S260 Motherboard Replacement: adım 8, 3 resimden 3.
    • Flip so the Vaio Logo is face down.
    • Locate and remove a total of 8 screws on the bottom.
  9. Sony Vaio VGN-S260 Motherboard Replacement: adım 9, 1 resimden 1.
    • Find and remove 5 screws (they all have arrows next to them) from cover.
  10. Sony Vaio VGN-S260 Motherboard Replacement: adım 10, 3 resimden 1. Sony Vaio VGN-S260 Motherboard Replacement: adım 10, 3 resimden 2. Sony Vaio VGN-S260 Motherboard Replacement: adım 10, 3 resimden 3.
    • Flip the laptop over so the Vaio logo is face up.
    • Use the spudger to pop up the upper casing.
    • Do not lift too much as the upper casing is attached to wires underneath.
    • Remove the wires that are attaching the upper casing to the motherboard.
  11. Sony Vaio VGN-S260 Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the upper casing.
  12. Sony Vaio VGN-S260 Motherboard Replacement, Power Adapter: adım 12, 2 resimden 1. Sony Vaio VGN-S260 Motherboard Replacement, Power Adapter: adım 12, 2 resimden 2.
    • Locate the yellow power adapter.
    • Follow its wire to white logic board connector.
    • Pull out the wire from white logic board connector.
  13. Sony Vaio VGN-S260 Motherboard Replacement: adım 13, 3 resimden 1. Sony Vaio VGN-S260 Motherboard Replacement: adım 13, 3 resimden 2. Sony Vaio VGN-S260 Motherboard Replacement: adım 13, 3 resimden 3.
    • Locate the screws on the fan filter casing.
    • Remove these screws.
  14. Sony Vaio VGN-S260 Motherboard Replacement: adım 14, 2 resimden 1. Sony Vaio VGN-S260 Motherboard Replacement: adım 14, 2 resimden 2.
    • Remove the screw next to the yellow power adapter.
    • Lift out power adapter and fan filter.
  15. Sony Vaio VGN-S260 Motherboard Replacement, Optical Drive: adım 15, 1 resimden 1.
    • Remove the screw holding the optical drive casing to the logic board.
  16. Sony Vaio VGN-S260 Motherboard Replacement: adım 16, 1 resimden 1.
    • Locate ribbon connecting optical drive case to logic board.
    • Pop off the ribbon.
    • Remove the metal PC-Card cage.
  17. Sony Vaio VGN-S260 Motherboard Replacement: adım 17, 1 resimden 1.
    • Remove the four screws holding the optical drive to the logic board.
  18. Sony Vaio VGN-S260 Motherboard Replacement: adım 18, 2 resimden 1. Sony Vaio VGN-S260 Motherboard Replacement: adım 18, 2 resimden 2.
    • Locate brown locking tab above optical drive.
    • Lift up on brown locking tab until ribbon is loose.
    • Gently slide out and remove the optical drive from the computer.
  19. Sony Vaio VGN-S260 Motherboard Replacement, Ethernet Ports: adım 19, 2 resimden 1. Sony Vaio VGN-S260 Motherboard Replacement, Ethernet Ports: adım 19, 2 resimden 2.
    • Remove the blue ribbon from the Ethernet Circuit Board.
  20. Sony Vaio VGN-S260 Motherboard Replacement: adım 20, 1 resimden 1.
    • Remove the screws near the Ethernet Port circuit board.
  21. Sony Vaio VGN-S260 Motherboard Replacement: adım 21, 1 resimden 1.
    • Remove the screws for the second ethernet circuit board.
  22. Sony Vaio VGN-S260 Motherboard Replacement: adım 22, 2 resimden 1. Sony Vaio VGN-S260 Motherboard Replacement: adım 22, 2 resimden 2.
    • Remove the ethernet ports.
  23. Sony Vaio VGN-S260 Motherboard Replacement, Hard Drive: adım 23, 2 resimden 1. Sony Vaio VGN-S260 Motherboard Replacement, Hard Drive: adım 23, 2 resimden 2.
    • Remove the screws holding the hard drive casing in place.
  24. Sony Vaio VGN-S260 Motherboard Replacement: adım 24, 1 resimden 1.
    • Find orange ribbon that is connected to the hard drive.
    • Find the holder of the ribbon and pop the ribbon off from it.
  25. Sony Vaio VGN-S260 Motherboard Replacement: adım 25, 1 resimden 1.
    • Remove the casing and the orange ribbon.
  26. Sony Vaio VGN-S260 Motherboard Replacement, Motherboard: adım 26, 2 resimden 1. Sony Vaio VGN-S260 Motherboard Replacement, Motherboard: adım 26, 2 resimden 2.
    • Remove screws on the motherboard.
  27. Sony Vaio VGN-S260 Motherboard Replacement: adım 27, 2 resimden 1. Sony Vaio VGN-S260 Motherboard Replacement: adım 27, 2 resimden 2.
    • Remove the nut using a 5mm nut driver.
    • Using a magnetic screwdriver handle will also work as well.
  28. Sony Vaio VGN-S260 Motherboard Replacement: adım 28, 2 resimden 1. Sony Vaio VGN-S260 Motherboard Replacement: adım 28, 2 resimden 2.
    • Remove the LCD display ribbon with a nylon spudger.
    • This is difficult to remove.
  29. Sony Vaio VGN-S260 Motherboard Replacement: adım 29, 3 resimden 1. Sony Vaio VGN-S260 Motherboard Replacement: adım 29, 3 resimden 2. Sony Vaio VGN-S260 Motherboard Replacement: adım 29, 3 resimden 3.
    • Gently lift the motherboard from the laptop.
    • The motherboard will be attached to the network wireless chip, which is also attached to the base of the laptop.
    • Remove the chip by popping the tabs on the side.
    • Slide out the network card.
    • You are now free to take the motherboard away from the base.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jeffrey Bryan
570 İtibar
11 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-4, Maness Spring 2010 Cal Poly, Team 16-4, Maness Spring 2010 üyesi
CPSU-MANESS-S10S16G4
4 Üyeler
30 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 7,333
