Ana içeriğe geç
Sony Vaio VGN-SR140E CD/DVD Drive Replacement
Neye ihtiyacın var
  1. Sony Vaio VGN-SR140E CD/DVD Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: adım 2, 1 resimden 1.
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: adım 3, 2 resimden 1. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: adım 3, 2 resimden 2.
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E CD/DVD Drive Replacement, CD/DVD Drive: adım 4, 1 resimden 1.
    • Use a Phillips #1 screwdriver to loosen all four screws. These screws are secured to their covers with retaining clips.
  5. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: adım 5, 1 resimden 1.
    • Lift the two covers with a fingernail or plastic opening tool from the sides the screws were present. Two tabs are securing the covers on the side opposite the screws.
  6. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: adım 6, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove both 6.5mm screws and set them aside.
  7. Sony Vaio VGN-SR140E CD/DVD Drive Replacement: adım 7, 1 resimden 1.
    • Gently slide the CD/DVD drive out of the laptop.
Sonuç
Jeremy
722 İtibar
4 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-6, Lauer Spring 2015 Michigan Tech, Team 1-6, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G6
2 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 1,131
