Ana içeriğe geç
Sony Vaio VGN-SR140E Hard Drive Replacement
Neye ihtiyacın var
  1. Sony Vaio VGN-SR140E Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E Hard Drive Replacement: adım 2, 1 resimden 1.
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E Hard Drive Replacement: adım 3, 2 resimden 1. Sony Vaio VGN-SR140E Hard Drive Replacement: adım 3, 2 resimden 2.
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Using a Phillips #1 screw driver, loosen both screws holding the cover in place. These screws are secured to the cover with retaining clips.
  5. Sony Vaio VGN-SR140E Hard Drive Replacement: adım 5, 1 resimden 1.
    • Lift the cover with a fingernail or plastic opening tool from the side where the screws are present and lift it off to the left.
  6. Sony Vaio VGN-SR140E Hard Drive Replacement: adım 6, 1 resimden 1.
    • The hard drive is covered by a thin, black, plastic flap. Gently lift the hard drive up and to the right.
    • Be careful not to damage the ribbon cable during this step.
  7. Sony Vaio VGN-SR140E Hard Drive Replacement: adım 7, 2 resimden 1. Sony Vaio VGN-SR140E Hard Drive Replacement: adım 7, 2 resimden 2.
    • Use the spudger or a fingernail to carefully release the lock securing the ribbon cable to the motherboard.
  8. Sony Vaio VGN-SR140E Hard Drive Replacement: adım 8, 2 resimden 1. Sony Vaio VGN-SR140E Hard Drive Replacement: adım 8, 2 resimden 2.
    • Grasp the ribbon cable carefully near the connector end. Remove it by pulling the cable away from the connector on the motherboard at a slightly upward angle.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jeremy
722 İtibar
4 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-6, Lauer Spring 2015 Michigan Tech, Team 1-6, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G6
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 928
