Ana içeriğe geç
Sony Vaio VGN-SR140E RAM Replacement
Neye ihtiyacın var
    1. Sony Vaio VGN-SR140E RAM Replacement, Battery: adım 1, 1 resimden 1.
      • Turn the laptop over and orient it as shown in the figure.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Vaio VGN-SR140E RAM Replacement: adım 2, 1 resimden 1.
      • Slide the lock latch to the right to release the battery lock.
      • Slide and hold the release latch to the left.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Vaio VGN-SR140E RAM Replacement: adım 3, 2 resimden 1. Sony Vaio VGN-SR140E RAM Replacement: adım 3, 2 resimden 2.
      • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Vaio VGN-SR140E RAM Replacement, RAM: adım 4, 1 resimden 1.
      • Using a Phillips #1 screwdriver, remove both screws. The screws are secured to the cover with retaining clips.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Vaio VGN-SR140E RAM Replacement: adım 5, 2 resimden 1. Sony Vaio VGN-SR140E RAM Replacement: adım 5, 2 resimden 2.
      • Lift the thin black plastic cover to access the RAM.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Vaio VGN-SR140E RAM Replacement: adım 6, 2 resimden 1. Sony Vaio VGN-SR140E RAM Replacement: adım 6, 2 resimden 2.
      • Apply light outward pressure to the locks on either side of the RAM. Rotate the RAM up slightly. Pull the RAM toward you to remove it.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Vaio VGN-SR140E RAM Replacement: adım 7, 3 resimden 1. Sony Vaio VGN-SR140E RAM Replacement: adım 7, 3 resimden 2. Sony Vaio VGN-SR140E RAM Replacement: adım 7, 3 resimden 3.
      • Using the same light outward pressure on the locks, lift the secondary RAM up and slide it away from you to remove it from its slot.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jeremy
735 İtibar
4 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-6, Lauer Spring 2015 Michigan Tech, Team 1-6, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G6
2 Üyeler
20 adet Kılavuz yazıldı
1Rehber Yorum
C'est trop cool
Joël Zanou - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 35
Her zaman: 886
