Ana içeriğe geç
Sony Vaio VGN-SR140E Screen Replacement
Neye ihtiyacın var
  1. Sony Vaio VGN-SR140E Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E Screen Replacement: adım 2, 1 resimden 1.
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E Screen Replacement: adım 3, 2 resimden 1. Sony Vaio VGN-SR140E Screen Replacement: adım 3, 2 resimden 2.
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E Screen Replacement, Screen: adım 4, 3 resimden 1. Sony Vaio VGN-SR140E Screen Replacement, Screen: adım 4, 3 resimden 2. Sony Vaio VGN-SR140E Screen Replacement, Screen: adım 4, 3 resimden 3.
    • Remove the rubber pads at all four corners of the screen bezel using a spudger. This will reveal four 5mm Phillips screws.
    • Use a Phillips #1 screwdriver to remove the four screws and set them aside.
  5. Sony Vaio VGN-SR140E Screen Replacement: adım 5, 1 resimden 1.
    • Remove the screen's plastic bezel. You may need to use slight pressure to release the clips that secure the bezel to the laptop.
  6. Sony Vaio VGN-SR140E Screen Replacement: adım 6, 2 resimden 1. Sony Vaio VGN-SR140E Screen Replacement: adım 6, 2 resimden 2.
    • Lift screen bezel up and off of the laptop.
  7. Sony Vaio VGN-SR140E Screen Replacement: adım 7, 3 resimden 1. Sony Vaio VGN-SR140E Screen Replacement: adım 7, 3 resimden 2. Sony Vaio VGN-SR140E Screen Replacement: adım 7, 3 resimden 3.
    • Close the laptop carefully and slowly while holding the screen with your thumb to prevent it from falling.
    • Lay the screen gently on the keyboard. This will reveal the screen's connector.
  8. Sony Vaio VGN-SR140E Screen Replacement: adım 8, 3 resimden 1. Sony Vaio VGN-SR140E Screen Replacement: adım 8, 3 resimden 2. Sony Vaio VGN-SR140E Screen Replacement: adım 8, 3 resimden 3.
    • Grasp the connector and gently pull it out.
  9. Sony Vaio VGN-SR140E Screen Replacement: adım 9, 1 resimden 1.
    • The screen can now be removed.
Sonuç
Jeremy
722 İtibar
4 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-6, Lauer Spring 2015 Michigan Tech, Team 1-6, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G6
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 1,175
