Ana içeriğe geç
Sony Vaio VGN-SZ120P Memory Replacement
Neye ihtiyacın var
  1. Sony Vaio VGN-SZ120P Memory Replacement, Battery: adım 1, 1 resimden 1.
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. Sony Vaio VGN-SZ120P Memory Replacement: adım 2, 1 resimden 1.
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Sony Vaio VGN-SZ120P Memory Replacement, Memory: adım 3, 2 resimden 1. Sony Vaio VGN-SZ120P Memory Replacement, Memory: adım 3, 2 resimden 2.
    • Unscrew the two memory panel screws and set the panel aside.
    • Ignore the removal of the heatsink panel. This does not need to be removed for RAM module access.
  4. Sony Vaio VGN-SZ120P Memory Replacement: adım 4, 3 resimden 1. Sony Vaio VGN-SZ120P Memory Replacement: adım 4, 3 resimden 2. Sony Vaio VGN-SZ120P Memory Replacement: adım 4, 3 resimden 3.
    • Lift the film covering to reveal the memory module with the tweezers.
    • Pull the tabs on both sides of the RAM away from the module. The module will pop up.
    • Repeat this step for the other RAM module located directly above the memory module just removed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan
154 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S25G89
4 Üyeler
63 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 14
Her zaman: 4,957
