Ana içeriğe geç
Sony Vaio VGN-SZ120P Mouse Assembly Replacement
Neye ihtiyacın var
  1. Sony Vaio VGN-SZ120P Mouse Assembly Replacement, Battery: adım 1, 1 resimden 1.
    • Set the computer display-side down.
    • Unlock the battery by sliding the port-side latch to the 'unlock' position.
  2. Sony Vaio VGN-SZ120P Mouse Assembly Replacement: adım 2, 1 resimden 1.
    • On the opposite side of the battery, press the release latch and slide the battery away from the main body to remove.
  3. Sony Vaio VGN-SZ120P Mouse Assembly Replacement, Keyboard: adım 3, 1 resimden 1.
    • Ignore the removal of the heat sink and memory panels as depicted. They do not need to be removed for the completion of this guide.
    • Remove the Torx security screw near the center of the battery-side edge.
  4. Sony Vaio VGN-SZ120P Mouse Assembly Replacement: adım 4, 2 resimden 1. Sony Vaio VGN-SZ120P Mouse Assembly Replacement: adım 4, 2 resimden 2.
    • Press the tabs on each side of the display-side of the keyboard with the flat edge of a spudger.
    • Pull the keyboard toward the mouse pad and gently lift up.
  5. Sony Vaio VGN-SZ120P Mouse Assembly Replacement: adım 5, 2 resimden 1. Sony Vaio VGN-SZ120P Mouse Assembly Replacement: adım 5, 2 resimden 2.
    • The keyboard is still attached by ribbon cable, don't try to remove the keyboard entirely yet.
    • Disconnect the ribbon cable by pressing the tabs on either side of the connector. Pull the cable out parallel to the connector.
    • Remove the keyboard.
  6. Sony Vaio VGN-SZ120P Mouse Assembly Replacement, Mouse Assembly: adım 6, 1 resimden 1.
    • Turn the laptop upside down.
    • Remove the three screws from the front mouse panel located on the bottom of the laptop.
    • Carefully flip the laptop back over. Remove three more screws from the top securing the panel. A ribbon cable will still be attached to the panel when you remove it.
  7. Sony Vaio VGN-SZ120P Mouse Assembly Replacement: adım 7, 2 resimden 1. Sony Vaio VGN-SZ120P Mouse Assembly Replacement: adım 7, 2 resimden 2.
    • Lift the mouse assembly just enough to access the connecting ribbon cable.
    • Lift the ribbon cable lock to remove the cable.
    • Carefully remove the mouse panel assembly and set aside.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ashley Brooks
312 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 25-89, Amido Spring 2010 Cal Poly, Team 25-89, Amido Spring 2010 üyesi
CPSU-AMIDO-S10S25G89
4 Üyeler
63 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 18
Her zaman: 3,474
