Ana içeriğe geç
Sony Vaio VPC-Y2190X Hard Drive Replacement
Neye ihtiyacın var
  1. Sony Vaio VPC-Y2190X Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Flip your laptop so that the bottom is facing up.
  2. Sony Vaio VPC-Y2190X Hard Drive Replacement: adım 2, 1 resimden 1.
    • Slide the “Lock” switch to the right.
    • Slide and hold the “Release” switch to the left.
  3. Sony Vaio VPC-Y2190X Hard Drive Replacement: adım 3, 2 resimden 1. Sony Vaio VPC-Y2190X Hard Drive Replacement: adım 3, 2 resimden 2.
    • While holding the “Release” switch, lift the lip of the battery.
    • Lift the battery up and out of the laptop.
  4. Sony Vaio VPC-Y2190X Hard Drive Replacement, Hard Drive: adım 4, 1 resimden 1.
    • Using a #0PH screwdriver, unscrew the three 4.80mm screws on the back of the device.
    • The screws are held into the panel by washers, they will not fall out once unscrewed.
  5. Sony Vaio VPC-Y2190X Hard Drive Replacement: adım 5, 1 resimden 1.
    • Remove the panel.
    • Use the #0PH screwdriver to remove the four 3.61mm screws.
  6. Sony Vaio VPC-Y2190X Hard Drive Replacement: adım 6, 2 resimden 1. Sony Vaio VPC-Y2190X Hard Drive Replacement: adım 6, 2 resimden 2.
    • Carefully lift the hard drive.
    • Remove the hard drive by pulling it to the left.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 343
