Ana içeriğe geç
Sony Vaio VPC-Y2190X RAM Card Replacement
Neye ihtiyacın var
  1. Sony Vaio VPC-Y2190X RAM Card Replacement, Battery: adım 1, 1 resimden 1.
    • Flip your laptop so that the bottom is facing up.
  2. Sony Vaio VPC-Y2190X RAM Card Replacement: adım 2, 1 resimden 1.
    • Slide the “Lock” switch to the right.
    • Slide and hold the “Release” switch to the left.
  3. Sony Vaio VPC-Y2190X RAM Card Replacement: adım 3, 2 resimden 1. Sony Vaio VPC-Y2190X RAM Card Replacement: adım 3, 2 resimden 2.
    • While holding the “Release” switch, lift the lip of the battery.
    • Lift the battery up and out of the laptop.
  4. Sony Vaio VPC-Y2190X RAM Card Replacement, RAM Card: adım 4, 2 resimden 1. Sony Vaio VPC-Y2190X RAM Card Replacement, RAM Card: adım 4, 2 resimden 2.
    • Use a #0PH screwdriver to unscrew the three 4.80mm screws.
    • Remove the panel.
  5. Sony Vaio VPC-Y2190X RAM Card Replacement: adım 5, 1 resimden 1.
    • Pull the metal tabs in opposite directions, away from the RAM card.
    • The RAM card will swing upwards.
  6. Sony Vaio VPC-Y2190X RAM Card Replacement: adım 6, 1 resimden 1.
    • Grab the RAM card from its center.
    • Gently pull the RAM card out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 321
