Ana içeriğe geç
Sony Vaio VPCCW17FX Fan Replacement
Neye ihtiyacın var
    1. Sony Vaio VPCCW17FX Fan Replacement, Back case: adım 1, 1 resimden 1.
      • Turn the laptop over and orient it as shown.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Vaio VPCCW17FX Fan Replacement: adım 2, 3 resimden 1. Sony Vaio VPCCW17FX Fan Replacement: adım 2, 3 resimden 2. Sony Vaio VPCCW17FX Fan Replacement: adım 2, 3 resimden 3.
      • Remove the battery by pinching the two lock tabs towards the center.
      • Next, lift up on the battery to remove it.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Vaio VPCCW17FX Fan Replacement: adım 3, 1 resimden 1.
      • Using a Phillips #00 screwdriver, remove the twenty-two 5.6 mm screws from the back of the laptop.
      • Be sure to remove all screws, including those that are typically covered by the battery.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Vaio VPCCW17FX Fan Replacement: adım 4, 3 resimden 1. Sony Vaio VPCCW17FX Fan Replacement: adım 4, 3 resimden 2. Sony Vaio VPCCW17FX Fan Replacement: adım 4, 3 resimden 3.
      • Now, remove the small covers from the back of the case.
      • Using a Phillips #00 screwdriver, unscrew the three 5.6 mm screws from the covers (one screw on the RAM cover [middle] and two screws on the Hard Drive cover [bottom right]).
      • Then, lift up on and remove these covers as shown in the third image.
      FixBot'a Sor
      Yorum Ekle
    5. Sony Vaio VPCCW17FX Fan Replacement: adım 5, 3 resimden 1. Sony Vaio VPCCW17FX Fan Replacement: adım 5, 3 resimden 2. Sony Vaio VPCCW17FX Fan Replacement: adım 5, 3 resimden 3.
      • Remove the hard drive.
      • Using a Phillips #00 screwdriver, unscrew the two remaining 4.9 mm screws holding the hard drive into place.
      • Next, lift up and pull outwards to release the hard drive from its socket.
      FixBot'a Sor
      Yorum Ekle
    6. Sony Vaio VPCCW17FX Fan Replacement: adım 6, 1 resimden 1.
      • Using your fingers, grasp the black tab and lightly pull up on the ribbon cable to detach it from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    7. Sony Vaio VPCCW17FX Fan Replacement: adım 7, 1 resimden 1.
      • After proper removal of all necessary screws, gently lift up on the back case to remove it.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Vaio VPCCW17FX Fan Replacement, Fan: adım 8, 3 resimden 1. Sony Vaio VPCCW17FX Fan Replacement, Fan: adım 8, 3 resimden 2. Sony Vaio VPCCW17FX Fan Replacement, Fan: adım 8, 3 resimden 3.
      • Locate the fan (top-right corner of the computer).
      • Using a Phillips #00 screwdriver, unscrew the six 2.7 mm screws that secure the fan to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Vaio VPCCW17FX Fan Replacement: adım 9, 2 resimden 1. Sony Vaio VPCCW17FX Fan Replacement: adım 9, 2 resimden 2.
      • This step can be skipped if you are just removing the fan to access another part of the device (such as the motherboard).
      • Using a Japanese Industrial Standard #00 screwdriver, unscrew four 3.7 mm screws located on the casing of the fan.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Vaio VPCCW17FX Fan Replacement: adım 10, 2 resimden 1. Sony Vaio VPCCW17FX Fan Replacement: adım 10, 2 resimden 2.
      • Using your fingers, grasp the white tab and firmly, yet gently, pull up on the wire to disconnect it from the motherboard.
      FixBot'a Sor
      Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 20
Her zaman: 1,468
