Ana içeriğe geç
Sony Vaio VPCCW17FX Fan Replacement
Neye ihtiyacın var
  1. Sony Vaio VPCCW17FX Fan Replacement, Back case: adım 1, 1 resimden 1.
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Fan Replacement: adım 2, 3 resimden 1. Sony Vaio VPCCW17FX Fan Replacement: adım 2, 3 resimden 2. Sony Vaio VPCCW17FX Fan Replacement: adım 2, 3 resimden 3.
    • Remove the battery by pinching the two lock tabs towards the center.
    • Next, lift up on the battery to remove it.
  3. Sony Vaio VPCCW17FX Fan Replacement: adım 3, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the twenty-two 5.6 mm screws from the back of the laptop.
    • Be sure to remove all screws, including those that are typically covered by the battery.
  4. Sony Vaio VPCCW17FX Fan Replacement: adım 4, 3 resimden 1. Sony Vaio VPCCW17FX Fan Replacement: adım 4, 3 resimden 2. Sony Vaio VPCCW17FX Fan Replacement: adım 4, 3 resimden 3.
    • Now, remove the small covers from the back of the case.
    • Using a Phillips #00 screwdriver, unscrew the three 5.6 mm screws from the covers (one screw on the RAM cover [middle] and two screws on the Hard Drive cover [bottom right]).
    • Then, lift up on and remove these covers as shown in the third image.
  5. Sony Vaio VPCCW17FX Fan Replacement: adım 5, 3 resimden 1. Sony Vaio VPCCW17FX Fan Replacement: adım 5, 3 resimden 2. Sony Vaio VPCCW17FX Fan Replacement: adım 5, 3 resimden 3.
    • Remove the hard drive.
    • Using a Phillips #00 screwdriver, unscrew the two remaining 4.9 mm screws holding the hard drive into place.
    • Next, lift up and pull outwards to release the hard drive from its socket.
  6. Sony Vaio VPCCW17FX Fan Replacement: adım 6, 1 resimden 1.
    • Using your fingers, grasp the black tab and lightly pull up on the ribbon cable to detach it from the motherboard.
  7. Sony Vaio VPCCW17FX Fan Replacement: adım 7, 1 resimden 1.
    • After proper removal of all necessary screws, gently lift up on the back case to remove it.
  8. Sony Vaio VPCCW17FX Fan Replacement, Fan: adım 8, 3 resimden 1. Sony Vaio VPCCW17FX Fan Replacement, Fan: adım 8, 3 resimden 2. Sony Vaio VPCCW17FX Fan Replacement, Fan: adım 8, 3 resimden 3.
    • Locate the fan (top-right corner of the computer).
    • Using a Phillips #00 screwdriver, unscrew the six 2.7 mm screws that secure the fan to the motherboard.
  9. Sony Vaio VPCCW17FX Fan Replacement: adım 9, 2 resimden 1. Sony Vaio VPCCW17FX Fan Replacement: adım 9, 2 resimden 2.
    • This step can be skipped if you are just removing the fan to access another part of the device (such as the motherboard).
    • Using a Japanese Industrial Standard #00 screwdriver, unscrew four 3.7 mm screws located on the casing of the fan.
  10. Sony Vaio VPCCW17FX Fan Replacement: adım 10, 2 resimden 1. Sony Vaio VPCCW17FX Fan Replacement: adım 10, 2 resimden 2.
    • Using your fingers, grasp the white tab and firmly, yet gently, pull up on the wire to disconnect it from the motherboard.
Sonuç
Ellie DePorter
310 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 20
Her zaman: 1,104
