Ana içeriğe geç
Sony Vaio VPCCW17FX Hard Drive Replacement
Neye ihtiyacın var
  1. Sony Vaio VPCCW17FX Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Hard Drive Replacement: adım 2, 1 resimden 1.
    • Slide the two latches towards the center of the battery to release it.
  3. Sony Vaio VPCCW17FX Hard Drive Replacement: adım 3, 2 resimden 1. Sony Vaio VPCCW17FX Hard Drive Replacement: adım 3, 2 resimden 2.
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Hard Drive Replacement: adım 4, 2 resimden 1. Sony Vaio VPCCW17FX Hard Drive Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the two 7.7 mm screws from the hard drive cover and place it to the side.
  5. Sony Vaio VPCCW17FX Hard Drive Replacement: adım 5, 3 resimden 1. Sony Vaio VPCCW17FX Hard Drive Replacement: adım 5, 3 resimden 2. Sony Vaio VPCCW17FX Hard Drive Replacement: adım 5, 3 resimden 3.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #00 screwdriver that hold the hard drive in place.
    • Use the tab to slide the hard drive away from the laptop.
    • Set the disconnected hard drive away from the laptop.
  6. Sony Vaio VPCCW17FX Hard Drive Replacement: adım 6, 3 resimden 1. Sony Vaio VPCCW17FX Hard Drive Replacement: adım 6, 3 resimden 2. Sony Vaio VPCCW17FX Hard Drive Replacement: adım 6, 3 resimden 3.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #00 screwdriver that cover the hard drive.
    • Use the tab to pull up on the metal cover and remove it.
    • You are now free to replace the hard drive.
Sonuç
Tiffani Beck
219 İtibar
2 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S8G5
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 1,755
