Ana içeriğe geç
Sony Vaio VPCCW17FX RAM Replacement
Neye ihtiyacın var
    1. Sony Vaio VPCCW17FX RAM Replacement, RAM: adım 1, 1 resimden 1.
      • Turn the laptop over and orient it as shown.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Vaio VPCCW17FX RAM Replacement: adım 2, 1 resimden 1.
      • Slide both latches to the center of the laptop in order to release the battery.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Vaio VPCCW17FX RAM Replacement: adım 3, 2 resimden 1. Sony Vaio VPCCW17FX RAM Replacement: adım 3, 2 resimden 2.
      • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Vaio VPCCW17FX RAM Replacement: adım 4, 2 resimden 1. Sony Vaio VPCCW17FX RAM Replacement: adım 4, 2 resimden 2.
      • Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) that is covering the RAM.
      FixBot'a Sor
      Yorum Ekle
    5. Sony Vaio VPCCW17FX RAM Replacement: adım 5, 1 resimden 1.
      • Lift the black plastic cover to assess the RAM.
      FixBot'a Sor
      Yorum Ekle
    6. Sony Vaio VPCCW17FX RAM Replacement: adım 6, 3 resimden 1. Sony Vaio VPCCW17FX RAM Replacement: adım 6, 3 resimden 2. Sony Vaio VPCCW17FX RAM Replacement: adım 6, 3 resimden 3.
      • Apply light, outward pressure to the locks on both sides of the RAM.
      • Rotate the RAM up and slowly pull towards you to remove it.
      FixBot'a Sor
      Yorum Ekle
    7. Sony Vaio VPCCW17FX RAM Replacement: adım 7, 3 resimden 1. Sony Vaio VPCCW17FX RAM Replacement: adım 7, 3 resimden 2. Sony Vaio VPCCW17FX RAM Replacement: adım 7, 3 resimden 3.
      • In order to remove the secondary RAM, use the same outward pressure on the locks.
      • Lift and slide out the RAM to remove it from the slot.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Mia Martinez
101 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S8G5
4 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 35
Her zaman: 1,570
