Ana içeriğe geç
Sony Vaio VPCCW17FX RAM Replacement
Neye ihtiyacın var
  1. Sony Vaio VPCCW17FX RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX RAM Replacement: adım 2, 1 resimden 1.
    • Slide both latches to the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX RAM Replacement: adım 3, 2 resimden 1. Sony Vaio VPCCW17FX RAM Replacement: adım 3, 2 resimden 2.
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX RAM Replacement: adım 4, 2 resimden 1. Sony Vaio VPCCW17FX RAM Replacement: adım 4, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) that is covering the RAM.
  5. Sony Vaio VPCCW17FX RAM Replacement: adım 5, 1 resimden 1.
    • Lift the black plastic cover to assess the RAM.
  6. Sony Vaio VPCCW17FX RAM Replacement: adım 6, 3 resimden 1. Sony Vaio VPCCW17FX RAM Replacement: adım 6, 3 resimden 2. Sony Vaio VPCCW17FX RAM Replacement: adım 6, 3 resimden 3.
    • Apply light, outward pressure to the locks on both sides of the RAM.
    • Rotate the RAM up and slowly pull towards you to remove it.
  7. Sony Vaio VPCCW17FX RAM Replacement: adım 7, 3 resimden 1. Sony Vaio VPCCW17FX RAM Replacement: adım 7, 3 resimden 2. Sony Vaio VPCCW17FX RAM Replacement: adım 7, 3 resimden 3.
    • In order to remove the secondary RAM, use the same outward pressure on the locks.
    • Lift and slide out the RAM to remove it from the slot.
Sonuç
Mia Martinez
101 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S8G5
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 1,231
