Ana içeriğe geç
Sony Vaio VPCCW17FX Speakers Replacement
Neye ihtiyacın var
  1. Sony Vaio VPCCW17FX Speakers Replacement, Speakers: adım 1, 1 resimden 1.
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Speakers Replacement: adım 2, 1 resimden 1.
    • Slide the two latches towards the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX Speakers Replacement: adım 3, 2 resimden 1. Sony Vaio VPCCW17FX Speakers Replacement: adım 3, 2 resimden 2.
    • Use fingernail or plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Speakers Replacement: adım 4, 2 resimden 1. Sony Vaio VPCCW17FX Speakers Replacement: adım 4, 2 resimden 2.
    • Using a Phillips #0 screwdriver to remove the two screws (Length: 7.7 mm) of the Hard Drive cover and place the cover to the side.
    • Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) from the RAM cover and place it to the side.
  5. Sony Vaio VPCCW17FX Speakers Replacement: adım 5, 1 resimden 1.
    • Using a Phillips #0 screwdriver, remove all twelve screws (Length: 7.7 mm) that hold the bottom cover.
  6. Sony Vaio VPCCW17FX Speakers Replacement: adım 6, 1 resimden 1.
    • Lift and remove the back cover.
  7. Sony Vaio VPCCW17FX Speakers Replacement: adım 7, 2 resimden 1. Sony Vaio VPCCW17FX Speakers Replacement: adım 7, 2 resimden 2.
    • Locate the fan and use a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold it in place.
    • Lift the fan and move it out of the way.
  8. Sony Vaio VPCCW17FX Speakers Replacement: adım 8, 2 resimden 1. Sony Vaio VPCCW17FX Speakers Replacement: adım 8, 2 resimden 2.
    • Begin removing the four screws with a Phillips #0 screwdriver (Length: 7.7 mm) from the back cover.
    • Place the cover out of the way.
    • Be careful to not pull any wires out while moving the cover.
  9. Sony Vaio VPCCW17FX Speakers Replacement: adım 9, 3 resimden 1. Sony Vaio VPCCW17FX Speakers Replacement: adım 9, 3 resimden 2. Sony Vaio VPCCW17FX Speakers Replacement: adım 9, 3 resimden 3.
    • Using a Phillips #0 screwdriver, remove the two screws (Length: 7.7 mm) that hold the speaker in place.
    • Follow the wire until you find the ribbon cable that holds the wires and pull straight out of the connect to remove it.
    • You are now free to replace the speakers.
    • There are two speakers so be sure to repeat the same steps for the second speaker.
Sonuç
Brianna Rukes
101 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S8G5
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 548
