Ana içeriğe geç
Sony Vaio VPCCW17FX Webcam Replacement
Neye ihtiyacın var
  1. Sony Vaio VPCCW17FX Webcam Replacement, Webcam: adım 1, 1 resimden 1.
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Webcam Replacement: adım 2, 1 resimden 1.
    • Slide both latches to the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX Webcam Replacement: adım 3, 2 resimden 1. Sony Vaio VPCCW17FX Webcam Replacement: adım 3, 2 resimden 2.
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX Webcam Replacement: adım 4, 2 resimden 1. Sony Vaio VPCCW17FX Webcam Replacement: adım 4, 2 resimden 2.
    • Remove the four rubber circles using the spudger located on each corner of the laptop.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver that are located under each rubber circle.
  5. Sony Vaio VPCCW17FX Webcam Replacement: adım 5, 2 resimden 1. Sony Vaio VPCCW17FX Webcam Replacement: adım 5, 2 resimden 2.
    • Slowly peel off the plastic covering around the screen.
    • Place it to the side once it is completely disconnected.
    • You may need to apply slight pressure to release the clips of the covering.
  6. Sony Vaio VPCCW17FX Webcam Replacement: adım 6, 3 resimden 1. Sony Vaio VPCCW17FX Webcam Replacement: adım 6, 3 resimden 2. Sony Vaio VPCCW17FX Webcam Replacement: adım 6, 3 resimden 3.
    • Remove the two screws (Length: 7.7 mm) using the Phillips #0 screwdriver that hold the Webcam in place.
    • Gently pull the webcam away from the laptop.
    • Slowly disconnect the two ribbon cable connectors by sliding them towards the wire to disconnect the webcam from the laptop.
Sonuç
Tiffani Beck
219 İtibar
2 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S8G5
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 1,106
