Ana içeriğe geç
Sony Vaio VPCEB11FM Hard Drive Replacement
Neye ihtiyacın var
  1. Sony Vaio VPCEB11FM Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Power down and disconnect the laptop from power supply.
    • Using your fingers, unlock the tab by pushing on the slide.
  2. Sony Vaio VPCEB11FM Hard Drive Replacement: adım 2, 1 resimden 1.
    • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
  3. Sony Vaio VPCEB11FM Hard Drive Replacement: adım 3, 1 resimden 1.
    • Pull the battery out.
  4. Sony Vaio VPCEB11FM Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. Sony Vaio VPCEB11FM Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Using the Phillips #01 Screwdriver, remove the two 7mm screws.
  5. Sony Vaio VPCEB11FM Hard Drive Replacement: adım 5, 3 resimden 1. Sony Vaio VPCEB11FM Hard Drive Replacement: adım 5, 3 resimden 2. Sony Vaio VPCEB11FM Hard Drive Replacement: adım 5, 3 resimden 3.
    • Use your fingers to pry the cover upward.
    • Unscrew the two 7mm screws.
    • Pull the plastic tab in the direction of the arrow to take out.
  6. Sony Vaio VPCEB11FM Hard Drive Replacement: adım 6, 2 resimden 1. Sony Vaio VPCEB11FM Hard Drive Replacement: adım 6, 2 resimden 2.
    • Lift plug side first.
    • Remove all the way.
  7. Sony Vaio VPCEB11FM Hard Drive Replacement: adım 7, 3 resimden 1. Sony Vaio VPCEB11FM Hard Drive Replacement: adım 7, 3 resimden 2. Sony Vaio VPCEB11FM Hard Drive Replacement: adım 7, 3 resimden 3.
    • Skip to next step if accessing other components.
    • Remove the 3mm screws with the Phillips #1 Screwdriver from hard drive bracket.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Maxine Filcher
1.153 İtibar
8 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-5, Rose Winter 2017 UW Tacoma, Team 1-5, Rose Winter 2017 üyesi
UWT-ROSE-W17S1G5
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 4,066
