Ana içeriğe geç
Sony Vaio VPCEB11FM Keyboard Replacement
Neye ihtiyacın var
  1. Sony Vaio VPCEB11FM Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Power down and disconnect the laptop from power supply.
    • Using your fingers, unlock the tab by pushing on the slide.
  2. Sony Vaio VPCEB11FM Keyboard Replacement: adım 2, 1 resimden 1.
    • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
  3. Sony Vaio VPCEB11FM Keyboard Replacement: adım 3, 1 resimden 1.
    • Pull the battery out.
  4. Sony Vaio VPCEB11FM Keyboard Replacement, DVD Drive: adım 4, 2 resimden 1. Sony Vaio VPCEB11FM Keyboard Replacement, DVD Drive: adım 4, 2 resimden 2.
    • Remove the 7mm screws with the Phillips #1 Screwdriver.
  5. Sony Vaio VPCEB11FM Keyboard Replacement: adım 5, 1 resimden 1.
    • Grasp the DVD drive's face plate with your fingers and pull out.
  6. Sony Vaio VPCEB11FM Keyboard Replacement, Keyboard: adım 6, 3 resimden 1. Sony Vaio VPCEB11FM Keyboard Replacement, Keyboard: adım 6, 3 resimden 2. Sony Vaio VPCEB11FM Keyboard Replacement, Keyboard: adım 6, 3 resimden 3.
    • Within the DVD drive compartment, press on the hole to push the keyboard out of its placement.
    • The keyboard may need to be loosened on its edges with a plastic spudger.
  7. Sony Vaio VPCEB11FM Keyboard Replacement: adım 7, 3 resimden 1. Sony Vaio VPCEB11FM Keyboard Replacement: adım 7, 3 resimden 2. Sony Vaio VPCEB11FM Keyboard Replacement: adım 7, 3 resimden 3.
    • Carefully pull the keyboard back to expose ribbon connector.
    • Using a spudger, or your finger tips, carefully slide the the ribbon keeper open.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Maxine Filcher
1.153 İtibar
8 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-5, Rose Winter 2017 UW Tacoma, Team 1-5, Rose Winter 2017 üyesi
UWT-ROSE-W17S1G5
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 1,973
