Ana içeriğe geç
Sony Vaio VPCEB11FM RAM Replacement
Neye ihtiyacın var
  1. Sony Vaio VPCEB11FM RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Power down and disconnect the laptop from power supply.
    • Using your fingers, unlock the tab by pushing on the slide.
  2. Sony Vaio VPCEB11FM RAM Replacement: adım 2, 1 resimden 1.
    • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
  3. Sony Vaio VPCEB11FM RAM Replacement: adım 3, 1 resimden 1.
    • Pull the battery out.
  4. Sony Vaio VPCEB11FM RAM Replacement, RAM: adım 4, 2 resimden 1. Sony Vaio VPCEB11FM RAM Replacement, RAM: adım 4, 2 resimden 2.
    • Unscrew the RAM cover plate using the Phillips #1 Screwdriver.
    • Once the cover has been loosened, pry the cover with your finger for it to come off.
  5. Sony Vaio VPCEB11FM RAM Replacement: adım 5, 3 resimden 1. Sony Vaio VPCEB11FM RAM Replacement: adım 5, 3 resimden 2. Sony Vaio VPCEB11FM RAM Replacement: adım 5, 3 resimden 3.
    • Use your fingers to gently pull the white plastic strip outward on both sides.
    • Once you pull the strip, the strip of RAM will loosen up. Once loose the strip of RAM should lift out.
    • Once done with the top strip of RAM continue for all continuous strips.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Maxine Filcher
1.153 İtibar
8 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 1-5, Rose Winter 2017 UW Tacoma, Team 1-5, Rose Winter 2017 üyesi
UWT-ROSE-W17S1G5
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 27
Her zaman: 1,986
