Giriş
This step-by-step guide will lead you through the process of removing the back panel of a Sony Vaio VPCEG26FX Laptop. The back panel would need to be replaced if cracked or broken. Removing the back panel requires very little force should be needed to remove the back panel. If difficult to remove, ensure that all the screws have been removed.
Loosen the two (7mm) screws that hold the hard drive panel in place with a JIS #0 screwdriver.
After you remove the battery, there is a small rectangular panel underneath where the battery was housed.
Remove the remaining eleven 7mm screws from back panel using the JIS #0 screwdriver.
