Ana içeriğe geç
Sony Vaio VPCEG37FM Battery Replacement
    1. Sony Vaio VPCEG37FM Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Unlock the battery by sliding the lock upwards.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Vaio VPCEG37FM Battery Replacement: adım 2, 2 resimden 1. Sony Vaio VPCEG37FM Battery Replacement: adım 2, 2 resimden 2.
      • Slide the release upwards and lift out the battery to remove.
      • Once battery is removed, long press the Power button for 30-60s and discharge any remaining power inside of the computer.
      • Put on the ESD bracelet, making sure the metal circle is touching your skin. Remove the alligator clip from the other end of the bracelet and insert the jack into the ground plug of an active electrical outlet. (the round hole). Do not move forward until you are grounded.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Morgynn Richlark
115 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 47
Her zaman: 2,018
