Ana içeriğe geç
Sony Vaio VPCEL17FX Hard Drive Replacement
Neye ihtiyacın var
  1. Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 1. Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 2. Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: adım 1, 3 resimden 3.
    • First, locate the hard drive slot on the under side of the laptop.
    • Unscrew the screws using your Phillips #00 screwdriver.
    • Set the two screws aside so you can screw them in later on when you're finished.
    • This should reveal a small metallic place holder that your hard drive belongs.
  2. Sony Vaio VPCEL17FX Hard Drive Replacement: adım 2, 2 resimden 1. Sony Vaio VPCEL17FX Hard Drive Replacement: adım 2, 2 resimden 2.
    • Unscrew the 4 hard drive bracket screws.
    • Once the screw is undone you can pull the place holder back to find the slot where the actual hard drive belongs.
    • Remember to set aside the screw so you can correctly install the hard drive.
Sonuç
The installation/replacement is a very easy task that can be done by anyone.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 611
