Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Place your device upside down with the bottom panel facing upwards.
Orient the device so the battery is away from you as shown
Unlock the battery by sliding the lock switch to the right.
Locate the release latch. Slide the latch to the left to remove the battery from your laptop.
Remove the four 5.2mm screws that are holding in the Disc Drive.
Grab the center of the drive and pull away from the computer. It should slide right out.
