Ana içeriğe geç
Sony Vaio VPCW21FX Keyboard Replacement
Neye ihtiyacın var
  1. Sony Vaio VPCW21FX Keyboard Replacement, Battery: adım 1, 3 resimden 1. Sony Vaio VPCW21FX Keyboard Replacement, Battery: adım 1, 3 resimden 2. Sony Vaio VPCW21FX Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio VPCW21FX Keyboard Replacement: adım 2, 3 resimden 1. Sony Vaio VPCW21FX Keyboard Replacement: adım 2, 3 resimden 2. Sony Vaio VPCW21FX Keyboard Replacement: adım 2, 3 resimden 3.
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: adım 3, 3 resimden 1. Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: adım 3, 3 resimden 2. Sony Vaio VPCW21FX Keyboard Replacement, Keyboard: adım 3, 3 resimden 3.
    • Open the Lid of the laptop
    • Then using they pry tool to carefully remove the plastic cover around the keyboard
    • It helps to pry from one of the larger keys as they have more room to fit the tool in
  4. Sony Vaio VPCW21FX Keyboard Replacement: adım 4, 3 resimden 1. Sony Vaio VPCW21FX Keyboard Replacement: adım 4, 3 resimden 2. Sony Vaio VPCW21FX Keyboard Replacement: adım 4, 3 resimden 3.
    • Close the lid and flip the laptop over
    • Loosen but do not remove the screw on center panel and remove Panel.
  5. Sony Vaio VPCW21FX Keyboard Replacement: adım 5, 2 resimden 1. Sony Vaio VPCW21FX Keyboard Replacement: adım 5, 2 resimden 2.
    • Remove the three 5mm screws that are holding in the keyboard.
  6. Sony Vaio VPCW21FX Keyboard Replacement: adım 6, 3 resimden 1. Sony Vaio VPCW21FX Keyboard Replacement: adım 6, 3 resimden 2. Sony Vaio VPCW21FX Keyboard Replacement: adım 6, 3 resimden 3.
    • Flip laptop over again and open the lid
    • Lift up the keyboard from the top and lean it toward you to expose the connector on the back
    • Grab the wire from the keyboard close to the connector and pull carefully to the left to disconnect it from the laptop.
Sonuç
Nicholas Corcoran
401 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 2,200
