Ana içeriğe geç
Sony Vaio VPCW21FX RAM Replacement
Neye ihtiyacın var
  1. Sony Vaio VPCW21FX RAM Replacement, Battery: adım 1, 3 resimden 1. Sony Vaio VPCW21FX RAM Replacement, Battery: adım 1, 3 resimden 2. Sony Vaio VPCW21FX RAM Replacement, Battery: adım 1, 3 resimden 3.
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio VPCW21FX RAM Replacement: adım 2, 3 resimden 1. Sony Vaio VPCW21FX RAM Replacement: adım 2, 3 resimden 2. Sony Vaio VPCW21FX RAM Replacement: adım 2, 3 resimden 3.
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio VPCW21FX RAM Replacement, RAM: adım 3, 3 resimden 1. Sony Vaio VPCW21FX RAM Replacement, RAM: adım 3, 3 resimden 2. Sony Vaio VPCW21FX RAM Replacement, RAM: adım 3, 3 resimden 3.
    • Loosen but do not remove the screw over RAM cover panel.
    • With the screw loosened but not removed, lift up and remove the panel.
  4. Sony Vaio VPCW21FX RAM Replacement: adım 4, 3 resimden 1. Sony Vaio VPCW21FX RAM Replacement: adım 4, 3 resimden 2. Sony Vaio VPCW21FX RAM Replacement: adım 4, 3 resimden 3.
    • Locate the mounting bracket holding the RAM Chips in the computer.
    • Pull silver tabs away from the chip.
    • The chip will pop up, this is normal.
    • Don't touch gold pins on RAM chip.
  5. Sony Vaio VPCW21FX RAM Replacement: adım 5, 2 resimden 1. Sony Vaio VPCW21FX RAM Replacement: adım 5, 2 resimden 2.
    • Slide RAM chip out by holding the sides of the chip and pull away from the computer.
    • Repeat previous steps for second RAM chip.
Sonuç
Nicholas Corcoran
401 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 24
Her zaman: 3,356
