Ana içeriğe geç
Sony WH-1000XM4 Microphone Array Replacement
Neye ihtiyacın var
  1. Sony WH-1000XM4 Microphone Array Replacement, Microphone Array: adım 1, 1 resimden 1.
    • Before beginning any repairs, press and hold the power button on the left ear cup for about 2 seconds until the blue light turns off.
    • Place your headphones onto a work surface, ear pads facing up.
  2. Sony WH-1000XM4 Microphone Array Replacement: adım 2, 1 resimden 1.
    • Use your thumb to depress the LEFT ear pad near the long outer edge, creating a gap between the cushion and the frame.
    • Insert the flat end of a spudger into the gap you've created, between the edge of the cushion and the frame.
    • Pivot the spudger down to unclip the long edge of the ear pad.
    • When the first clip disconnects, you'll hear an audible clicking sound.
    • This may take a considerable amount of force. If the cushion won't click out of place, move your spudger to different points along the long edge.
  3. Sony WH-1000XM4 Microphone Array Replacement: adım 3, 1 resimden 1.
    • Remove the left ear pad.
  4. Sony WH-1000XM4 Microphone Array Replacement: adım 4, 1 resimden 1.
    • Remove the foam liner from the left ear cup's speaker.
  5. Sony WH-1000XM4 Microphone Array Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the four 8.4 mm screws securing the left ear cup cover.
  6. Sony WH-1000XM4 Microphone Array Replacement: adım 6, 1 resimden 1.
    • Flip the headphones over, ear cups facing down.
    • Use your fingers to lift up and flip over the right ear cup cover.
    • Don't try to completely remove the cover just yet—it's still attached with many cables.
    • Grip the touch ribbon cable and pull it straight out of its connector on the main board to remove it.
    • Remove the ear cup cover.
  7. Sony WH-1000XM4 Microphone Array Replacement: adım 7, 1 resimden 1.
    • The microphone array uses strong adhesives, you may find it useful to utilize the IFixit iOpener kit's heating pad in aiding its removal.
    • Remove the microphone array ribbon from the ear cup that has just been removed.
    • The microphone array is the copper-colored ribbon along the edge of the ear cup.
Sonuç
Spencer Decker
493 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-1, Harley Fall 2023 IUPUI, Team 2-1, Harley Fall 2023 üyesi
IUPUI-HARLEY-F23S2G1
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 75
Son 30 gün: 377
Her zaman: 2,146
