Ana içeriğe geç
Sony WH-1000XM4 Swivel Replacement
Neye ihtiyacın var
  1. Sony WH-1000XM4 Swivel Replacement, Swivel: adım 1, 3 resimden 1. Sony WH-1000XM4 Swivel Replacement, Swivel: adım 1, 3 resimden 2. Sony WH-1000XM4 Swivel Replacement, Swivel: adım 1, 3 resimden 3.
    • Using an opening tool, pry off the right ear muff and remove the underlying foam.
  2. Sony WH-1000XM4 Swivel Replacement: adım 2, 2 resimden 1. Sony WH-1000XM4 Swivel Replacement: adım 2, 2 resimden 2.
    • Using an opening tool, pry off the left ear muff and remove the underlying foam.
  3. Sony WH-1000XM4 Swivel Replacement: adım 3, 2 resimden 1. Sony WH-1000XM4 Swivel Replacement: adım 3, 2 resimden 2.
    • Remove the four silver screws on both sides of the headphones using a Phillips #000 screwdriver.
  4. Sony WH-1000XM4 Swivel Replacement: adım 4, 3 resimden 1. Sony WH-1000XM4 Swivel Replacement: adım 4, 3 resimden 2. Sony WH-1000XM4 Swivel Replacement: adım 4, 3 resimden 3.
    • Flip the headphones.
    • Lift the back of both sides of the headphones.
  5. Sony WH-1000XM4 Swivel Replacement: adım 5, 2 resimden 1. Sony WH-1000XM4 Swivel Replacement: adım 5, 2 resimden 2.
    • Detach the ribbon cable connecting the backplate to the right ear.
  6. Sony WH-1000XM4 Swivel Replacement: adım 6, 2 resimden 1. Sony WH-1000XM4 Swivel Replacement: adım 6, 2 resimden 2.
    • Detach the yellow thermal sensor ribbon cable from the motherboard.
  7. Sony WH-1000XM4 Swivel Replacement: adım 7, 2 resimden 1. Sony WH-1000XM4 Swivel Replacement: adım 7, 2 resimden 2.
    • Detach the data/pwr connector from the motherboard using an opening tool.
  8. Sony WH-1000XM4 Swivel Replacement: adım 8, 1 resimden 1.
    • Remove the two screws from the motherboard using a Phillips #000 screwdriver.
  9. Sony WH-1000XM4 Swivel Replacement: adım 9, 2 resimden 1. Sony WH-1000XM4 Swivel Replacement: adım 9, 2 resimden 2.
    • Disconnect the white ribbon cable.
  10. Sony WH-1000XM4 Swivel Replacement: adım 10, 3 resimden 1. Sony WH-1000XM4 Swivel Replacement: adım 10, 3 resimden 2. Sony WH-1000XM4 Swivel Replacement: adım 10, 3 resimden 3.
    • Move the data/pwr cable from the inside of the board to the outside.
  11. Sony WH-1000XM4 Swivel Replacement: adım 11, 2 resimden 1. Sony WH-1000XM4 Swivel Replacement: adım 11, 2 resimden 2.
    • On the left ear, detach the ribbon cable attaching the nfc from the back panel to the motherboard.
  12. Sony WH-1000XM4 Swivel Replacement: adım 12, 1 resimden 1.
    • Remove the data/ pwr connector from board.
  13. Sony WH-1000XM4 Swivel Replacement: adım 13, 2 resimden 1. Sony WH-1000XM4 Swivel Replacement: adım 13, 2 resimden 2.
    • On the right ear, rotate the motherboard and remove the two screws from the hinge using a Phillips #000 screwdriver.
    • On the left ear, remove the two screws from the hinge using a Phillips #000 screwdriver.
  14. Sony WH-1000XM4 Swivel Replacement: adım 14, 2 resimden 1. Sony WH-1000XM4 Swivel Replacement: adım 14, 2 resimden 2.
    • On the right ear, lift the hinge and push it out.
  15. Sony WH-1000XM4 Swivel Replacement: adım 15, 2 resimden 1. Sony WH-1000XM4 Swivel Replacement: adım 15, 2 resimden 2.
    • On the left ear, lift the hinge and push it out.
  16. Sony WH-1000XM4 Swivel Replacement: adım 16, 2 resimden 1. Sony WH-1000XM4 Swivel Replacement: adım 16, 2 resimden 2.
    • Remove the black hinge piece from the data/ pwr cable.
  17. Sony WH-1000XM4 Swivel Replacement: adım 17, 2 resimden 1. Sony WH-1000XM4 Swivel Replacement: adım 17, 2 resimden 2.
    • Using a screwdriver, remove the rubber band.
  18. Sony WH-1000XM4 Swivel Replacement: adım 18, 2 resimden 1. Sony WH-1000XM4 Swivel Replacement: adım 18, 2 resimden 2.
    • Use an opening tool to remove the cover.
  19. Sony WH-1000XM4 Swivel Replacement: adım 19, 1 resimden 1.
    • Lift up the data/ pwr cable.
  20. Sony WH-1000XM4 Swivel Replacement: adım 20, 1 resimden 1.
    • Remove the two screws from the swivel using a Phillips #000 screwdriver.
  21. Sony WH-1000XM4 Swivel Replacement: adım 21, 2 resimden 1. Sony WH-1000XM4 Swivel Replacement: adım 21, 2 resimden 2.
    • Push out the metal bit from the swivel piece using a spudger.
    • Pull out the metal bit.
  22. Sony WH-1000XM4 Swivel Replacement: adım 22, 2 resimden 1. Sony WH-1000XM4 Swivel Replacement: adım 22, 2 resimden 2.
    • Remove the old swivel.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Jian Mejia
490 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 4-13, Kershman Fall 2023 CSU Los Angeles, Team 4-13, Kershman Fall 2023 üyesi
CSULA-KERSHMAN-F23S4G13
1 Üye
3 adet Kılavuz yazıldı
3 Yorum
really helpful, thank you! my swivel snapped. I started from Step 18 and removed the cover halfway. re-inserted the swivel then locked the metal bit back. i don't have the replacement piece and it will snap again if twisted too far, but this works for now. thanks!!
jianne - Yanıt
Here are a few suggestions:
1) Do a google search for 'sony headphones wh1000xm4 replacement plastics'
2) SONY Replacement Parts Website (what they offer) I found at this site.
3) Joe's SONY WH-1000XM4 Repair Parts I found at this site.
- The individual part you needed is offered along with a replacement metal clip.⏎
4) Check eBay - Currently (2/9/24) I see the part you need along with the two piece that attaches from the swivel joint to the speaker for about $11.99 USD
sonnyhung - Yanıt
I hear a creaking sound on my left earcup and have tried everything to remove it (tape, lube, opening the sides up) but to no avail. Should I do this guide and check if the creaking is in the hinge part? Thanks.
EJ Vinuya (EJ) - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 156
Son 30 gün: 839
Her zaman: 4,244
