Ana içeriğe geç
Sony WH-1000XM5 Battery Replacement
Neye ihtiyacın var
  1. Sony WH-1000XM5 Battery Replacement, Earpads: adım 1, 3 resimden 1. Sony WH-1000XM5 Battery Replacement, Earpads: adım 1, 3 resimden 2. Sony WH-1000XM5 Battery Replacement, Earpads: adım 1, 3 resimden 3.
    • Place the edge of an iFixit opening tool under the earpad cushion.
    • Slide it alongside the edge of the cushion until it detaches from the rest of the headphones
  2. Sony WH-1000XM5 Battery Replacement, Battery: adım 2, 2 resimden 1. Sony WH-1000XM5 Battery Replacement, Battery: adım 2, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the eight screws along the outer inside edge.
    • There should be a piece of grey foam you can simply remove to uncover the centre 4 screws.
    • Flip the headphones to the other side and slow lift up the back plastic cover piece.
    • Gently remove the touch sensor's ribbon cable by pulling it out evenly from the main board.
  3. Sony WH-1000XM5 Battery Replacement: adım 3, 3 resimden 1. Sony WH-1000XM5 Battery Replacement: adım 3, 3 resimden 2. Sony WH-1000XM5 Battery Replacement: adım 3, 3 resimden 3.
    • Disconnect the touch pad.
    • Pull out the battery, then disconnect it.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Miranda
234 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-4, Santin Spring 2024 UMass Dartmouth, Team 1-4, Santin Spring 2024 üyesi
UMASSD-SANTIN-S24S1G4
3 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
Hey folks, thanks for taking the time to layout this procedure. These headphones are amazing, and this really helps me get my friends onboard.
placebomessiah - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 29
Son 7 gün: 156
Son 30 gün: 680
Her zaman: 6,610
