Ana içeriğe geç
Sony WH-1000XM5 Earcup swivel Re-attachment - incomplete
Neye ihtiyacın var
    • Using the spugger pull the earpad inward, and pry the ear pad up and away from the earcup
  1. Sony WH-1000XM5 Earcup swivel Re-attachment - incomplete, Separate back of earcup: adım 2, 1 resimden 1.
    • We separate the back of the ear cup to get better acsess to the arm later
    • Remove the non glued down foam, and the 8 marked screws
  2. Sony WH-1000XM5 Earcup swivel Re-attachment - incomplete, Remove headband screw: adım 3, 1 resimden 1.
    • this screw is easyer to acsess without the back of the headphone cup
  3. Sony WH-1000XM5 Earcup swivel Re-attachment - incomplete, Remove earcup arm screw and plate: adım 4, 1 resimden 1.
    • Rushed for time, i didnt remember to take a photo of this part, please forgive me
    • there is a screwed and plate covering the attachment hardware that has come lose its location is indicated here:
    • We can use the access back here to hold onto the silver mounting screw and make sure we can screw the arm back together
  4. Sony WH-1000XM5 Earcup swivel Re-attachment - incomplete, remove wire clamp mold, and re-attach arm: adım 5, 1 resimden 1.
    • pull out this adjustable arm piece out of the headband
    • Unscrew the wire free from the adjustable arm piece, letting the arm spin freely around the wire.
    • screw the adjustable arm piece back on-to the earcup arm, in my case there was some resistance from a lip on the screw that prevented it becoming unscrewed in the first place. i was able to gently push past it multiple times till it was screwed on snugly
  5. Sony WH-1000XM5 Earcup swivel Re-attachment - incomplete, Reasemble: adım 6, 1 resimden 1.
    • go backwards though the steps to re-assemble
    • as always, i added a little Easter egg to my free repairs.
Sonuç
Sorry there are not more detailed photos, I was rushed to fix this and making it up as I go along.
If i can fix it, so can you <3
2 farklı kişi bu kılavuzu tamamladı.
Conor Bone
463 İtibar
2 adet Kılavuz yazıldı
Ekip
LGBTQ Technicians LGBTQ Technicians üyesi
Community
33 Üyeler
96 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 82
Son 30 gün: 363
Her zaman: 4,512
