Ana içeriğe geç
Sony WH-CH700N Headphone Pad Cover Replacement
Neye ihtiyacın var
  1. Sony WH-CH700N Headphone Pad Cover Replacement, Headphone Pad Cover: adım 1, 1 resimden 1.
    • Identify the free edge of the ear pad.
  2. Sony WH-CH700N Headphone Pad Cover Replacement: adım 2, 3 resimden 1. Sony WH-CH700N Headphone Pad Cover Replacement: adım 2, 3 resimden 2. Sony WH-CH700N Headphone Pad Cover Replacement: adım 2, 3 resimden 3.
    • Gently pull the free edge up.
    • Slight pressure is needed, but there is no glue.
    • Fully remove the ear pad.
    • If yours are more deteriorated, make sure to remove all excess material.
  3. Sony WH-CH700N Headphone Pad Cover Replacement: adım 3, 1 resimden 1.
    • Repeat with the other side.
  4. Sony WH-CH700N Headphone Pad Cover Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Microfiber Cleaning Cloths
    $3.99
    Satın Al
    • Gently wipe the exposed surface with an alcohol swab or microfiber cloth.
    • Do not scrub hard in order to avoid damaging the headphones.
  5. Sony WH-CH700N Headphone Pad Cover Replacement: adım 5, 1 resimden 1.
    • Identify the wider part of the headphone pad.
  6. Sony WH-CH700N Headphone Pad Cover Replacement: adım 6, 3 resimden 1. Sony WH-CH700N Headphone Pad Cover Replacement: adım 6, 3 resimden 2. Sony WH-CH700N Headphone Pad Cover Replacement: adım 6, 3 resimden 3.
    • Find the lip of the leather replacement pad.
    • Line up the new ear pad with one side of the exposed headphones, wider end towards the top.
    • Gently stretch one end of the ear pad over one end of the headphone.
    • You can anchor on the top of the ear pad by tilting the headphone out at an angle.
  7. Sony WH-CH700N Headphone Pad Cover Replacement: adım 7, 3 resimden 1. Sony WH-CH700N Headphone Pad Cover Replacement: adım 7, 3 resimden 2. Sony WH-CH700N Headphone Pad Cover Replacement: adım 7, 3 resimden 3.
    • Work your way around the ear pad, pulling the leather over the lip.
    • Pull from the inside out so that the leather catches on the lip.
    • You can use your whole hand as a grip to make sure that the leather does not slip off.
  8. Sony WH-CH700N Headphone Pad Cover Replacement: adım 8, 2 resimden 1. Sony WH-CH700N Headphone Pad Cover Replacement: adım 8, 2 resimden 2.
    • Repeat on the other side of the headphones.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Jackson Inagi
193 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 2-1, Johann Winter 2023 Cal Poly, Team 2-1, Johann Winter 2023 üyesi
CPSU-JOHANN-W23S2G1
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 27
Son 30 gün: 141
Her zaman: 1,624
