Ana içeriğe geç
Sony WH-CH720N Battery Replacement
Neye ihtiyacın var
  1. Sony WH-CH720N Battery Replacement, Earmuff: adım 1, 1 resimden 1.
    • Place the headphones down on a table, and orient them in this way.
  2. Sony WH-CH720N Battery Replacement: adım 2, 3 resimden 1. Sony WH-CH720N Battery Replacement: adım 2, 3 resimden 2. Sony WH-CH720N Battery Replacement: adım 2, 3 resimden 3.
    • Remove the earmuff.
    • Check introductions to ensure you remove the correct side earmuff for each repair guide!
  3. Sony WH-CH720N Battery Replacement, Battery: adım 3, 3 resimden 1. Sony WH-CH720N Battery Replacement, Battery: adım 3, 3 resimden 2. Sony WH-CH720N Battery Replacement, Battery: adım 3, 3 resimden 3.
    • Remove the four 5 mm screws in the right using a Phillips #00 screwdriver.
    • Remove the speaker panel to reveal the battery.
  4. Sony WH-CH720N Battery Replacement: adım 4, 2 resimden 1. Sony WH-CH720N Battery Replacement: adım 4, 2 resimden 2.
    • Unplug the battery with tweezers
  5. Sony WH-CH720N Battery Replacement: adım 5, 3 resimden 1. Sony WH-CH720N Battery Replacement: adım 5, 3 resimden 2. Sony WH-CH720N Battery Replacement: adım 5, 3 resimden 3.
    • Gently remove the battery from the device using the plastic spudger.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Followed this, and all good, thank you. The wires attaching the speaker to the board are very thin and not very long, so super caution needed. Replacement battery was 15 Euro, and was advertised as for 1000MX4 charging case, but fitted and works perfectly. Insane that you have to take the thing apart just to replace the battery though...
Graham Monro - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 60
Son 30 gün: 266
Her zaman: 4,023
