Giriş
This repair guide will help you learn how to locate, remove, and replace the battery for the Sony WH-CH720N. The battery is in the right side of the headphones. This is necessary in the event the headphones stop accepting a charge or refuse to power on despite charging.
DO NOT puncture the battery, as it might explode. Dispose of the battery in the proper receptacle.
Neye ihtiyacın var
Remove the four 5 mm screws in the right using a Phillips #00 screwdriver.
Remove the speaker panel to reveal the battery.
Bir başkası bu kılavuzu tamamladı.
