Giriş
This guide demonstrates how to replace the earpad cushions on your Sony WH-H900n headphones in just six easy steps. If you've noticed wear and tear on your current earpad cushions and want to give your headphones a fresh look and feel, the replacement is straightforward and hassle-free.
Ensure you've acquired replacement earpads specifically designed for the Sony WH-H900n model. Additionally, use a plastic prying tool to safely separate the old earpad cushions from the headphones to avoid causing damage to your headphones.
Before you begin, turn off your headphones and disconnect from the charger.
Neye ihtiyacın var
Place the edge opening tool between the headphones and earpad cushion, gently pry upward to release the clips securing the earpads.
Once you have completed the steps for both sides you are now able to enjoy your headphone just like when it was new.
